Lightplay
Everything posted by Lightplay
  1. This is the product I use, http://www.amazon.com/Ground-Hide-Glue-1-Pound/dp/B003AYTJSC/ref=sr_1_cc_2?s=aps&ie=UTF8&qid=1398639536&sr=1-2-catcorr&keywords=Hyde+glue. Mix with water heat to 140,(i use a hotplate, place glue/water mixture in jar, place jar in water bath)
  2. Good day Scott, i'm a Scott also! I use hide glue in certain applications on models. I use it very often in the marquetry work that i do. It has many great attributes as you have stated. One that is not and is the reason i use it is when it drys it is HARD! Regular pcv glues when fully cured have some flexability in them. Pull off cured glue waste from around a applicator neck and you can bend it. Hide glue is like glass, it will snap. On the benjamin latham model that I just started it requires you to glue four pieces together to form the keel. After gluing them together and letting them set overnight the keel is dead strait and will not flex when pressure is applied. When the bulkheads are attached the body of the ship is very rigged and will not warp! Just another attribute of a great product!
