lcopley98
Phantom 1868 by lcopley98 - Model Shipways - First Build
in - Kit build logs for subjects built from 1851 - 1900
Hello shipbuilders,
After only a few days of biting my nails, my Phantom kit finally came in via USPS. It arrive much faster than I thought it would. My confirmation email told me that it would be shipped via FedEx Ground and that it would take 5-7 business days. It only took USPS a couple days, so I was pleased. Upon opening the shipping box, I was greeted by a very nice looking Blue Box!
Opening the box overwhelmed me. The plans seem so detailed, but this is only a beginner design. I thought, "What have I gotten myself into?" Haha! I double checked to see if all the parts were there. I must be honest and say that this took awhile. I have no idea what some of the parts listed are. So, I'll say that I think everything is there! But, if I end up missing something, I am sure it will be no problem to replace later on down the road.
I examined my hull and found that it seems a little crooked in some spots. Especially the rear of the hull.
Do I just sand this down to make it look as even to the naked eye?
Well, I began trying to fit the two hull templates together. Reading Chuck's practicum, I found that I need to shave a little bit off the back end. (I think that is the stern?) However, I found it very difficult to remove the wood with my Hobby knife and #11 blades. You can see how I tried to take a little bit off and sand it down. I think that I will buy a carving tool tomorrow to make this a little easier. That is, unless someone else has a better method. So the back of the hull I left a lone for the evening with hopes that I would find an easier method to trim some of that excess wood off.
Onto the front of the hull, I also ran into some problems. I've read the other build logs and everyone seems to bypass this step pretty easily. I was't kidding around when I said I was a beginning. I have two photos and was hoping someone could give me a little advice on how the front template should fit.
In the picture above, the 'R' matches with the edge of the boat (These are called rabbet lines, I think). Am I correct in living that line up with the edge? If this is the case, you can see the gap that remains toward the middle of the hull. I have tried a couple different things with sand paper, but I can't quite seem to get that to lower any. Where should I sand to make this fit better? Or....
I matched the template up toward the center of the hull. You can see that this way there is a small gap in the curve of the hull and the R line does not quite match up to the edge. My gut tells me that the first image is right, I am just not sanding in the correct spot to make the template match up.
Problems problems! And this is only the beginning. Any help is welcome!
