caveman
475 profile views
  1. Chuck and Russ, Thank you for the advices. I've read those articles, but I understand them more clearly as I practically build the model Doing the stuff teaches a lot. Maybe it's not a perfectionist approach but I will use the kit planks. Let's see how it happens for the moment. I understood and liked the "cap of the pin" trick, I'll do it also. Thanks again. Baris.
  2. Hi, I'm a novice modeler who is trying to build Gretel Yacht at the moment. I'm about to finish the first layer planking already. My question is, how will I plank the second layer? How will I stabilize them on top of the first layer planks as the glue dries? Should I pin them? I don't think the pin holes will look good afterwards. Also, I'm concerned that the second layer planks are very thin (0.5 mm). I should not spill excess glue on the planks, they will look really bad. I've read the planking guides on thie site but I couldn't see proper visual guide for this second layer planking. If you can lead me to an article, I would appreciate very much. Thanks, Baris.
