jay913
Everything posted by jay913
  1. Captain Al: I just put it on my bench, pulling the dust away from me. Generally I switch it on no matter why I do, sanding, working with CA glue and epoxy, soldering. when sanding, I always turn the voltage up to 12v to increase the air flow in order to filter as many air bound particles as possible. Normally, I keep my purifier runs @ 7- 9v , less air flow and a bit quieter. Mike Y: brushless PC cooling fan is very quiet. but when the air is pulling through the filter, that is going to generate some wind noise. My Purifier's Noise level @12v : (65-70 dB) brushless Fan without filters : ( 55-60 dB)
  2. 3 filtration layer, (pre-filter->HEPA Filter->activated carbon filter), I m using 2 used DC 12v PC fan to pull the air. decrease the voltage to control the air flow. A Very simple design, quite easy to build. The only disadvantage is the filter aren't re-useable.
  3. In my opinion, this is the most important tool on my bench. https://youtu.be/T0WAnV_R8X0
  4. Bob, my 4hp treadmill use pwm to control the speed. yours should have something similar. hope this can help you understand more about treadmill motor and pwm https://www.instructables.com/id/Use-a-Treadmill-DC-Drive-Motor-and-PWM-Speed-Contr/ Jaager, thanks for you information, but my spindle sander is not design for normal size woodworking project, just for model making or small project. my biggest drum is 1 3/8" wide, never had motor over heat problem before, but I will put an thermometer in it to track the temperature inside
  5. Will you consider using PCB drill bit. size from 0.1 - 3.0 mm I purchase 2 set from ebay
  6. I use a PWM module to control the speed of the motor. 3:56 300-3100 rmp.
  7. A homemade machine for ship modelling. https://youtu.be/7H2AdnW_CJ4
