halfmoonheinz
Everything posted by halfmoonheinz
  1. Thanks for the answers. I will not use nails :-)
  2. Hi! I am very new to model ships and started my first kit, the Corel Half Moon. In many tutorials I read that the planks of the first layer can be placed using the small nails and after gluing remove the nails again. But why remove the nails? I ask because I have fitted the first two planks and I bent them using the Iron method. So the planks have a nice shape of the hull but I could not bend them as exact as they did not need a little support from nails and clamps. And as the area on the rips where the planks are glued is small I would sleep better knowing that there are nails supporting the glue. Especially as the planks should stay there for hopefully many years. Or is there a way the planks can be fixed after they are all attached to the hull? I saw an build log where the builder coated the whole first layer with wet white glue to secure and harden the planks. Is that a good idea? Thanks for the help.
