thelastronald
Everything posted by thelastronald
  1. Hello guys, In this tutorial I'm gonna share my way to determine the shape of 2nd planking hull: Prepare some pieces of A3 Paper (297mm x 420mm / 11.7’’x16.5’’), a paper cutter, a ruler, a measuring tape (or any flexible ruler/ thread) , and masking tape. measure the distance from the deck to the keel at the widest point. This is x. the length from stem to stern at the widest point is y. cut the paper into strips, and the size of the paper strip is: width = the width of plank, length = y and the amount of the paper strips = x/ the width of plank Put the strips of paper in order Cutting out the plank follow the shape of each paper strip. .... .... Hello? anybody home?
  2. The plywood is cheap, but it can't touch water. There’s one safe way to Bend those kits made by Plywood: using steam-bending. 1. put it into a food steamer 2. steam above water for 10 minutes 3. Bending the Curve. 4. When it cooling down, repeat all steps above until you finish it. But if the thickness of plywood less than 4 mm, using an iron(put a wet cloth under it) Bending the plywood while it is hot.
  3. Always measuring the size of kits by a human model: We know the length of body in 1:50 scale is about 36mm, but it's hard to imagine, such as Stair step height, the Size of a Table.. and so, let's make a human model with the wood or paper on the cheap.
  4. the cheaper nail files (you can get them from the body shop) Using the colored side to smooth small parts. and the white side to buff to shine. this oil painting is cutted from An art magazine the picture frame is one of the construction model (21mm x11 mm)
  5. Hi guys, I’m a newbie here, and I come from Taiwan(not Thailand). here I'd like to show you my little tips & tricks: You can get the wooden Christmas card or any wooden book card: to make carved doors or carved wall And the lead ball is better then steel balls to simulating the cannonball …. using syringe to control the flow of glue May the force be with you.
