jauber
Status Updates posted by jauber
I'm interest in your CNC Router and there are plenty of those on Amazone. So to get that frame contour I presume you needed a CAD software then transfer the data (Cartesian point) to another software or directly on the CNC Router. Could expand a little bit more. Would greatly appreciated.
Robert (Jauber).
By the way, your work is tremendous. Wish I could achieve that level of skill.
Hi Robert,
for the CNC router work you need three diferent software. First one is CAD software (I´m using TurboCad). The second one is Cut2D (transfer to this software is made through dxf files from TurboCad). This software prepare data for milling that uses the third software - MACH3. MACH3 software controls directly CNC router.
marsalv
Thank you very much for the clarification. I already have a CAD (AutoCAD and Via CAD) and Mach 3 could be bought with the CNC Router. But how about Cut2D software, which one you use… Desktop or Pro?
In another life I use to program CNC machine but everything was under the same platform (CADAM then merge to CATIA) They make our life very easy. Get the Engineering drawing, select contour, choose which machine, select tooling from a bank and direct to the post to validate the NC program then send to the DNC.
I really enjoy following your work and progress. There is so much to learn from all of you guys.
Best regards
RT(Jauber)
