Frazer
Everything posted by Frazer
  1. I think that I may have answered my own question. I received some information by email this evening and it appears that 'Sovereign of the Seas' was built with a 2 degree forward rake on the foremast and 3 and 4 degrees aft rake on the main and mizzen respectively.
  2. Yes, I think that you are right on this. The best figure I have been able to come up with so far is based on some measurements that I have taken from some section drawings that I lifted out of a microfilm copy of 'Fragments of Ancient English Shipwrightry', Matthew Baker, c. 1570 Careful measurement of this and other sections gives an approximation of 30:1, which looks about right. The ratio seems to hold true for any upper deck width, certainly for this period. I should note that although Matthew Baker is a bit early for the period I am interested in (1637),some portions of the manuscript were written in the early part of the 17th century so it does reflect the evolving practice of the time. Regards, Frazer
  3. Thanks Brian I Think I have a good solution to building up the camber OK using laminated paper in progressively narrower strips and then sanding back. I have used a similar technique before and the resulting composite is very strong and provides a good bed for the planks proper. The question is really how much should I build it up by to get a final curve that looks right for the period? The widest part of the visible waist is about 125 mm and I am guessing that the centre line would need to be built up 3-4 mm but this is a guess. There must be a shipwrights rule of thumb for this. Anyone know? Regards, Frazer
  4. Hi there I am at the early stages of building the De Agostini 'Sovereign of the Seas' and noticed that the plywood decks are all flat athwartships. This does not look right and I would like to plank up a slightly cambered deck as would have been the case on a real ship. Does anyone know how much camber or curvature would have been applied to a deck of this period? Regards, Frazer
  5. Evening all, Has anyone got any recommendations or advice on an appropriate rake for the masts on a 17th century English warship? I am at the early stages of building the De Agostini 'Sovereign of the Seas' and noticed that all the masts are upright, which doesn't look right. Best regards, Frazer
