Hello All!
I got some Minwax Wipe on poly, warm satin, love the material, using a brush to spread it and a rag to remove wet residue after about a minute of spreading.
How many coats would you do? Instructions say 2-3 coats, any advice or experience? I want good protection but at the same time like to complete this at some points!
how many coats is up to you. once you have a finish that pleases you, you're done. usually the wood sucks up the first, or even the second coat.
be sure to let it dry completely between coats, then sand with a 600 grit to get the fuz down.
