dbar1
Everything posted by dbar1
  1. Hi guys Do you know what happened to the website modelships.de ? It used to have very good quality photos of model ships at high resolution. Somehow it is down and has been like this for quite some time now. Many thanks.
  2. Hi guys
    I need some advice in the cross jack sling which holds the main yard to the mast. Should the sling be served ? BTW i m building HMS victory. Thnks
  3. Indeed alot of members seem to have a wide theoretical and practical knowlege, something which i unfortunately lack sometimes. Anyway it's good to share.
  4. Thanks Rob for your detailed explanation. I appreciate yr fewdback 😊
  5. Hi matrim. Thanks alot for yr reply which gave me some thoughts from a practical perspective. You are right and I agree with yr comments. Someone else gave me a reply to my query and noted that the middle mast shld be 1.5 to 2 degrees towards stern. This makes lots of sense and also goes in line with yr reply. Thnks and regards David
  6. Hi Danny. Thanks very much for your answer. I appreciate your feedback. You solved my issue😊 Regards, David
  7. Hi guys, I am currently building HMS Victory and have a small difficulty of a generic nature which needs some help. What is the angle at which the main mast is normally fixed to the deck? I am not sure whether this shld be 90 degrees or slightly inclined toward the stern. Drawings on the plan show the latter but i am bot sure. Thanks for yr help.
