Everything posted by Daniel Dusek
Thanks Guys, Nigel-Yes, I plan to make also copper tiles. Ed Saur, Ulises Victoria-At this moment it is hard to write what models will be next, it also depend on quality of sources (mainly quality of plans), but I would like to do De Zeven provinzien after the Santisima as I wrote earlier. But parallel to this big kits I everytime work also on some smaller projects (as Dutch statenyacht for example). Daniel
Thanks Nigel, Acually I use exactly what you recommend-the marks on the frames for exact positions of the more important plans (planks with gun ports). The planking will be done in three steps: 1) red planks (around gun ports) 2) blue planks -these planks could be adjust or fill if it is need, because they will be not visible (planks under wales) 3) wales-black planks, the wales overlap the blue planks as it is shown in the picture This system should guarantee exact planking above the waterline. Daniel
Hello Guys, Thanks for your comments. Richard, the planks on the deck will be engraved, and it look similar like the caulking as you wrote, you can see it for example on my model of Nuestra Senora (picture below). Actually also the planks of the hull was caulked similar like decks, it is visible for example on Batavia ship: https://gretavanderrol.files.wordpress.com/2010/08/bowsprit-crop.jpg https://upload.wikimedia.org/wikipedia/commons/8/8d/20110417_Lelystad%3B_Batavia_Haven_12_ship_at_Batavia_Harbour.JPG I use pear wood for the second planking as it is the best possible material for that, it is not dark but very easy for staining (The model of Dutch yacht in this thread is also planked by pear wood and then stained into darker tone). So for this reason I do not think it is need to sand all the char. And I prefer to make the model colored so in that case there is absolutely no problem with the char. Boyd, you are right that any variation of shape could lead to problem with exact fitting of planks but I think these problems could be only on the hull under the waterline due to quite simple shape above the waterline but the hull under waterline should be copper sheathing, so there is no problem to use putty. Anyway, there will be no problem to offer standard wooden strips instead of second laser planking . Best regards Daniel
Hello, I made some progress on Santisima Trinidad. Last week I finish second layer of planking on 3D model. In this kit all planks (both first and second layers) will be cut by laser for as easy as possible assembly. I hope I will be able to post some photos of prototype before the end of year. Best regards Daniel
Hello, Kevin Omland from Oyster Bay, NY USA sent us photo of building stave church Gol in 1/87 scale with some notes from building. Although its not ship model i think it is very nice work, if you are interested you can see it here: http://dusekshipkits.com/stave-church-gol1 Best regards Daniel Dusek
The scale of Santisima Trinidad is 1/72. The box on the top is originally reinforcement of the hull during building but Nigel Brook notify me on this forum that it would be also great for putting it upside down as you wrote so in production version I will make it little higher for this purpose Daniel
Hello All, As I promised here are some photos of the prepared kits Santisima Trinidad (after aplication of filler and sanding first planking) and Dutch Statenyacht. The Santisima Trinidad is my biggest project, length of only hull is almost 90cm. In these kits will be all planks of first planking cutted by laser for easier build. best regards Daniel Dusek
Hello All, Last two weeks I tried to do some sculptures for the new kit-Dutch Statenyacht. I decide to try to learn work in 3D sculpting software-SCULPTRIS and then to print in on 3D printer. As I found the SCULPTRIS is superb software for that and it is free, here is the link: http://pixologic.com/sculptris/ On the lictures you can see the SCULPTRIS virtual model of fish sculpture and result from 3D printer.
