gobi71
Everything posted by gobi71
  1. I first made of copper wire rings 0.1 thickness 2 mm in diameter.then with a pair of pliers I gave form directly on the piece.
  2. Lately I worked a few Deadeye. were 1 mm in diameter, and are of plum wood
  3. still working on the lower deck. i have a problem , and hope somebody here can help me. I do not know how these ships were painted inside.rif Winfield's book I found only how to paint the exterior.thank you.
  4. i start populating the lower deck . for instant the riding bitts , hatch and step for bowsprit.
  5. After processing the block exterior , I simply detached pieces, one by one, carefully numbered,worked inside and thickness, and relocated using keel.
  6. Excuse me, I was rude. my name is gabriel. vasile gabriel , and i am from romania. I use methods that do not differ greatly from what you know.I draw inspiration from the work of Narin majgeldinov, aka woodeater.(whom I thank).I just have a good view.do not use a magnifying glass or glasses, but a head lamp, very strong. for the hull i worked a block of pear wood , composed of slices of 1 mm thickness, and glued together with newsprint. Thank you for your attention.
  7. for construction i use pear wood. i start to build the orlop deck , adnd now the lower deck
  8. Dear colleagues, although a member of this forum for some time, this is the first post. I started building model while hms leopard 1790 1/300 scale. i use drawing from the book of rif winfield. here are some pictures of the model .
