Reci
Everything posted by Reci
  1. Then sand down all over the hull with 220/240 grit sanding blocks
  2. Beveling process... Bevel all the edges around the frames with 120/180 grit sanding block in appropriate shape and dimension. Stringers will be guide for the direction and shape of the application and lasermarks around the frames will be guide for the dosage of the application. When the lasermark disappears, it means dosage of the application is OK for that section.
  3. Hi... The second group project I completed this year. I will share the construction step by step. Kit Content...
  4. Hi Antony tnx; This kit is being produced by KGMODEL .... If you Google search , you may easily find further info.
  5. Painting of the hull and decal application * Decal processes
  6. Painting of the hull and decal application * Gloss cote processes
  7. Painting of the hull and decal application * Paint processes antifouling paint waterline
  8. Painting of the hull and decal application * sanding sealer processes
