Blacky
Members-
Everything posted by Blacky
Trying to complete all the furniture before i start working on gun deck. I made all i wanted for nelson's cabin. Moving to furniture for officers room below captains. I reworked chairs. Now the back side is narrow compared to front and legssupport is curved like the real ones. I also beveled table edge and corrected legs angle. Small drower completes the set.
Another day, another chair. This time i tried even more detailed model. I used yellow cedar in addition to pear for this one. It is as thin as it could be and fits perfect with the desk. Previous chairs were a bit bulky and didn't match the scale quite right. I used my middle finger just to show how small it is. Edit: i see now that i forgot one detail Reference link https://www.flickr.com/photos/mark_iliff/25740887074
After 2 coats of linseed oil. The wood color is now a little bit warmer and darker and reflects environment. I used dry brushing method. I applied a little bit of oil to kitchen paper and than used small brush to transfer oil to the wood. I plan to apply 2 more layers tomorrow on larger surfaces, sand them gently and than apply the final layer
Thank you @Patrick Haw. I went on a vacation and took a little break from work but did bring some wood and tools with me 😉, modeling is not work right. I saw that vanguard models is selling 3d printed version of furniture so i wanted to see how good i can make the same from wood. Here is my first attempt. I used swiss pear. What do you think?
After spending a few hours finding the best approach to border the gunports I have decided to add an additional 2 planks from the inside of the gunport to make better support for the lower border and then the rest 3 sides were easy to add. I used the mitre cutter tool for precisely cutting borders and it proved to be a good investment. I highly recommend it.
Question: how do you usually make gunports when the deck is narrow? The blueprint suggests C. I tried using gunport blueprint but it is way off so. My ship dimensions are off 1mm from the blueprint so i am marking ports myself. Actually find it a lot of fun. This is the current state of my agi. I have done the sanding and it seems quite smooth. Found only one incorrection that i will need to fill with filler and sand again
Thanks @allanyed. I think you are right. Now that the first layer is finished i think it is safe to trim the first three to the right dimension. But first, sanding, cutting the gunports and then i am moving to the interior. I also plan to do custom version of the agamemnon figurine but all in its time
