Serhii
Everything posted by Serhii
  1. Hello! All sails are on their place. Step by step go to finish In reality it's beautiful, really great. On photo looks not so good. But I really like it
  2. Hello! Rigging is really hard work It was just one clove hitch. I roughly counted and got about 900-1000 such hitches on my model.
  3. Hello all! Here is my current state, I've finished masting and stated rigging. 110 of 120 are built.
  4. Hello! I continue building Bounty, work on masting. Some photos with my progress since last time: Ancors are finished Boat is finished: Work on masts mostly Best regards!
  5. Hello! Some updates in photos Binnacle and building which instruction called flag box Pumps, plumbs and cargo Deadeyes and chains. That was difficult, 36 chains in total, I've made 22, still work on it Started building a boat. It should be one planking layer, but I could not do it good enough, so I puttyed it and started second planking And one more view with stove chimney That's all for now, almost 90 of 120 magazine numbers are behind
  6. Hello! Looks like I finished work on hull Added some decoration, rudder And some deck staff
  7. Looked at my own hatch photo and now I can see, that rings are not ideal. Some of them are really good, but not all. I will redo several to make ideal circle.
  8. Hello! Deck hatch is done. This one from instruction And this is mine I've made 8 thinner planks instead of 6 thick. And made smaller rings. Almost done the hull, in few days I'll remove glue, paint and varnish it and go next
  9. Some updates. Last month I worked on second plank layer and did a lot of sanding, painting and sanding again. Some photos: It was the most boring stage, so one week I had a rest and built plastic 1/72 Corsair And again sanding and painting Last painting and currently my Bounty looks like this
  10. Planking is finished started sanding, it will take some time for sure
  11. Parcel with some interesting has arrived. Some of it I used. Now I'm waiting for another one with drill/grinder, after getting it I will sand planking, by hands it's going to be very long process.
  12. Hello! Not much progress so far, I've almost finished first plank layer.
  13. After day of work. Today has arrived parcel with fluorescent powder, I'm going to do some light lamps. At first I thought about led light but don't want have a deal with wires, batteries etc, so will do lights using chemistry power
  14. Hello! I've made bulwarks and started planking. I'm still thinking about not doing hole in the Ship, because i feel I can't do it ideal, I'm learning on this ship. Also I've noticed that it does not correspond to Bounty anatomy of the Ship plans. Eg. Al kit internals are closer then eaglemoss kit ((( On the other hand I can always place it near the wall and nobody will see it if result is not good enough for me.
  15. It was local ebay analogue, so don't think can be useful for you. One guy bought magazines one by one but never started build and then sold whole set. This part work was issued 10 years ago so only private sellers can have it I guess. Actually it's an Occre kit, many shops have it, Artesania Latina has Bounty in 1/48 scale with interiors shown also.
  16. Hello! I've finished upper deck planking, covered by linseed oil and installed it. Also made some small staff as cannon and bales of goods. Next step is the hull planking.
  17. Hello! Thanks guys. So, for now there only several steps out of instructions I made. Doors - I've added door handle and hinges. Door trim - they suggested to use 3 on 3 mm plank, but it's about 15 cm in reality. I guess it's possible but looks like too much and on model it looked ugly, so I did them from 1 on 2 mm planks. Deck flooring - it was suggested to use pencil to "caulk" deck, but I did not like result, so I bought bottle of tar and use it. It smells but I like the way it looks Also on lower decks I used scheme from instruction - every second row on the same level, but on the upper deck I plank as I saw on different plans on other ships - every forth row on the same level and it looks more natural. For painting I used three kinds of stain - oak, beech and so called 'dark wood'. Matt acrylic varnish for coating. For lower deck I used plastic lattice from kit, but for upper deck I'm going to order wooden one. Last pictures are the current state. I'm working on upper deck planking. Comparing to longboat in 1/48th scale Bounty is huge.
  18. Hello all! That's my second wooden model build. The first one was 18th century longboat from Model Shipways. I built a lot of plastic 1/72nd scale planes of WW2, but some day I saw wooden kits and tried to build one and I like it When I worked on longboat I knew that something would be next and searched for new kit to build. I've bought Emma C. Berry from Model Shipways, cause thought that it must be the same good as longboat. In reality I was upset by it. Actually by it instructions and fittings, so poor, not clear and almost no fittings. Then I bought Artesania Latina Botter. Good kit, but very poor instructions and no any word of rigging. But for me it's the most important part, I just like to build models, I'm not specialist, so I need good instruction for rigging. OK, maybe model for future. Then I read about partworks and it looked like a good idea, because in 100 - 140 magazines instructions definitely must be good and detailed. So I bought full set of Eaglemoss Bounty (120 parts) and started working on it. I've chosen Bounty because of it's scale and good price - whole set cost me 150 US dollars, I guess it's very good price. Occre kit, which is the same one costs 450$ in local store. I've started this build month ago and currently I've done 30 of 120 magazine steps. Some photos from previous steps and later I will describe my changes to build process.
