jmegnin@ymail.com
Everything posted by jmegnin@ymail.com
  1. To popeye2sea jmegnin here got your message and I’m staying the course I have already followed your instructions and have drilled those holes in the mast top. So with that being said I will continue to march with it and I will let you know how it turned out with this part of the instructions. Many thanks for the information and instructions.
  2. mtaylor got the message and stand corrected thanks. I was on the Constellation back in 1970 and I'am sorry to say that was what I was told. I'll keepthe new info in mind thanks again.
  3. Good day popeye2sea jmegnin here got your message and drawing yes it is the same set of instructions In detail B it shows B block with instructions to tie to mast top I see that is toward the stern of the ship, but it does not show the location of the block from port to starboard and there is no pre-drilled holes for the attachment of the block. Can you help. Also, I have had the honor of visiting both the Constitution and her sister ship the Constellation located in Baltimore. Great ship and history.
  4. Hi Popeye2sea jmegnin here I am referring to the upper halyards of each mast tops and it would be greatly appreciated if I could get the actual location of the b blocks and how they are attached to the mast tops
  5. Reference upper halyards b block tied to mast tops where do the blocks attach ie centered or to the left or right of tops Constitution 1:96 scale
  6. Hi out there My name is Jim and I have a question on the placement/attachment of the 'b' block to the mast tops in the running rigging( w/o sails ). Any info would be great and if more info is required you can contact me at XXXXX.XXX (Email addy removed by moderator to prevent you being spammed.
