Alfonse
  1. Many thanks. Excellent work. My build never looks this clean. I guess I should use a bit less glue.
  2. Figure 40.jpg in your blog is a great example of what I'm asking about. I believe it is called a diamond cut because, the tip of the column actually looks like a big diamond. Thanks again.
  3. Thanks for your response. The "diamond" cuts I'm talking about are the triangular looking cuts made at the tips of most standing columns. If you look at Mamoli's instructions for the Friesland page 2, it is shown as part number 46, figure 10. Thanks.
  4. Hello, I know this may be a bit late, but could you please explain, with photos if possible, or even drawings, how you were able to make all those "diamond" cuts so symmetrical, and precise? Also, if you don't mind, the gratings on the first level seem to pop out of the deck, but you have the borders somehow tapered as you reach the grating. Again, photos would be great. Appreciative and desperate novice. Many thanks.
