Iro
Everything posted by Iro
  1. And that's it for today, more progress photos coming soon. I'm getting ready to cover the hull with copper plates, I think it will take some time. But in the meantime I'll try to upload some photos of painting the deck and all the elements. Best regards. Ahoj 🙂
  2. Some parts from the set are unacceptable to me. I am forced to make them myself. I still have a dilemma about choosing the color of the deck, whether it should be more bluish gray or maybe bluish brown. In different photos in Real Charles W. Morgan looks slightly different colors. I think bluish brown will be a better solution for painting the deck. I would be happy to hear some advice from other experienced modelers or those lucky ones who have visited the ship in person.
  3. The deck is in place, glued with epoxy resin. I had plenty of time to place the finished deck in the right place. This did not protect me from epoxy leakage in the hole where the rudder is. But every cloud has a silver lining. I started producing all the parts on the deck one by one. For now, in raw form, so that when the time comes, I can paint and polish them.
  4. Hello everyone again. I haven't been here for a long time and even more time has passed, progress has been made so I decided to add a few new photos. Greetings Iro.
  5. More parts and corrections. The incorrectly sized bowsprit went in for correction.
  6. Hi Paul. Thank you very much for your kind words. Thank you also for your understanding and patience, I made a bit of a mess in the post. Oh my. Now I think I have the situation under control. First attempts at gluing the deck, the effect is satisfactory I think. I used epoxy resin to glue it, thanks to which I had a lot of time to adjust it calmly, about two hours for the resin to harden. Attention! You have to watch out for resin leaks, think carefully about planning the gluing and prepare everything in advance.
  7. The deck and playing with pegs that I made from 0.3mm fishing line. It is not a faithful copy of the deck because over the years of intensive use of the ship, the arrangement of the boards is a complete chaos and without being there I am not able to faithfully recreate what is there.
  8. Another painting and masking. This time I used Vallejo 70913 and 71057 paints, yellow ochre and workshop black according to the RAL sampler.
  9. First painting after previous cleaning and checking for glue residue. I wanted to make the hull skin elements visible as much as possible and the detail of the plank structure as visible as possible. To achieve this, remember to dilute the paint and use a drying retarder. Good and careful preparation of the masking for work with an airbrush is half the battle.
  10. And more elements are arriving on the ship, the shipyard is working at full speed, although in reality it is painstaking tinkering and corrections to elements I was not satisfied with. I decided to make fasteners, I made the device by making a 0.4mm hole in a flat bar and a 0.3mm drill. I knocked them out of an aluminum can, making small circles.
  11. Next stage of the deck. I chose a different path to achieve the goal. Below are some photos of my work with matter.
  12. Thank you for your kind words. My work with this model began with this very portal. Searching for information about this ship led me to this place. Charles W Morgan is the history of America, so I found the most information about this ship here and in the process I discovered many fantastic modelers who struggle with the subject of its construction. I am from Poland, I hope that my sentences are quite legible, my English is not the best and I am forced to use a translator.
  13. Next stage of the deck. I chose a different path to achieve the goal. Below are some photos of my work with matter.
  14. Thank you for your kind words. My work with this model began with this very portal. Searching for information about this ship led me to this place. Charles W Morgan is the history of America, so I found the most information about this ship here and in the process I discovered many fantastic modelers who struggle with the subject of its construction. I am from Poland, I hope that my sentences are quite legible, my English is not the best and I am forced to use a translator.
    1. Show previous comments  1 more
    2. Iro
      Iro
      Hi Paul, I'll do that. I'm a bit confused. Can the ones on top be removed then? Best regards
    3. Iro
      Iro
      Everything transferred, I also added a few more photos.
    4. Paul Le Wol
      Paul Le Wol
      Hi Iro, here is a screenshot of your build log.
      Make sure you use this box when you want to add to your build log.
  15. My Charles is supposed to be an aged model, linden wood is perfect for this project, it adds a natural age to the model and the atmosphere of those times. The lower part of the ship is made of copper, which makes it easier to make the planking, which does not require so much focus. The modeler should focus his energy and precision on watching the hull axis and symmetry, controlling rotation and uncontrolled deformation while the glue is drying. At this stage, there is still a lot that can be fixed.
  16. According to the plans included in the kit, I couldn't figure out exactly what the stern looked like. I found original photos that dispelled all my doubts and in the course of creating the model I made several corrections to the mistakes I had made.
  17. The model is very interesting in terms of rigging, it has a whale suspension system and a gangway on which sailors worked. It does not have a large number of cannons, its weapons are seven boats for harpooners, buckets, barrels and a furnace for rendering fat. When building the model, you have to constantly watch the axis of symmetry and the delicate curves of the deck and bulwark, which define the beauty of this hull. All lines are curves that you have to focus on, in addition to this there are elements of hull reinforcements that have to be rhythmically set vertically, preferably in relation to the level (line) of the ship's draft.
  18. A few words about the kit itself. Since I am not one of those who complain, I will focus on the positives. Although not the best, linden wood offers great possibilities. This type of wood behaves a bit like a sponge, it can be crushed, flattened, bent and formed almost like plasticine. Warning! You have to be careful about its delicacy, because an inadvertent scratch with a fingernail can carve an unnecessary scratch in the material. Modeling plans made with care, although I often have the impression that there are no lines that would make the task easier. Fortunately, there are many photos of models already made by other modelers and photos of a real ship, which greatly helps to check the correctness of your own interpretation of reading the executive plan, thus helping to protect yourself from making a mistake.
    1. Show previous comments  2 more
    2. Iro
      Iro
    3. Iro
      Iro
    4. Iro
      Iro
  19. Hello to all interested. This is the journal of the Iro shipyard, from the construction of the Charles W. Morgan ship. My adventure with matter, the struggle with patience and the passage of time. Since childhood, I have been fascinated by travel and the world that has passed. Explorers of old times, fantastic travelers struggling with the power of nature, brave people full of passion like modern astronauts sailing through the spaces of infinity. With sailors greetings Iro
