drftrman
Everything posted by drftrman
  1. I did not have any pins and was struggling to keep the false deck against the bulkheads, so I drilled holes and used toothpicks. After getting the false deck glued down, I realized that the front two bulkheads are not quite lined up as you can see in the cut-outs on the false deck. Not sure if this matters much, but don't know if there is anything I can do about it now.
  2. I assumed that the rear bulkhead had to be filed down so that the false deck would lay flat along the bulkheads.
  3. After getting the bulkheads all glued up, I realized that the rear bulkhead did not stay aligned properly. I had to use an Exacto knife to cut through the glue along the joint and get it re-glued straight.
  4. Thanks Chris, Luckily there are a lot of resources here and youtube.
  5. Hello all, I have decided to build the HMS Cruiser 1:64 by Caldercraft as my first build. I have a feeling that I will be asking a lot of questions here.
