Pitts2112
Everything posted by Pitts2112
  1. First time modeler trying to use Chuck's plank bending method on the Lady Nelson. My question is what's the technique for getting the sharp bend required on the last couple of inches of the plank to get around the first rib and into the bow? I'm getting the bend on the rest of the plank OK, but I've broken 3 of them trying to get that last bit in. I think that if I don't get the bend sharp enough then CA glue isn't going to be strong enough to hold the end of the plank in place. Any tips will be greatly appreciated!
  2. Based on everyone's advice, I think I'll stick with the razor knife and sanding block for now. This will be my first model, after all, and if I think I'm going to notice the difference in results between the methods, I'm probably fooling myself. Thanks everyone for the kind advice!
  3. I'm a firm believer in this tool rule. Until I end up in a tool shop, that is. Good advice on all your points. Thanks very much!
  4. This is the kind of rig I was thinking of, or maybe even a shooting board type of thing since I'm also a little worried about keeping 90 degree angles.
  5. So maybe worth getting an inexpensive plane and trying it out? Sounds good. Thanks!
  6. Hello, all, I'm getting ready to start my first kit, the Amanti Lady Nelson. I've been absorbing the website here which is an amazing resource. I have one question about tools for tapering hull planks. My only experience with wooden models is from a couple of balsa wood aircraft when I was a kid and I remember having a really hard time getting quality results with X-Acto blades on that wood, particularly trying to make long taper cuts on thin strips. Are the planking woods in ship kits easier to work with? Would a modeler's plane give better results than a razor knife? Thanks for any tips!
