richbdm17
436 profile views
  1. Thanks Bill for the response. I gently bent the metal casting after using a 3 sided file to notch a small grove on the backside between the window panes. This worked out fine. But like you I need to do some major filling-in above and below the windows. Rich
  2. Thanks for the info Mort...I'll give it a try. Rich
  3. Great job! I am also building the Mamoli kit. Can you tell me how you curved the stern windows (pc#68) to match the curve of pcs#70 & #71? Appreciate any help/suggestions you can give. Thanks, Rich
  4. Need some help...the window metal walls (white metal casting) at the stern, both sides (pc#68), came flat but they need to be curved to match the upper and lower castings. Any suggestions on how to curve them? Don't want to make a mistake that I will loose sleep over! Open to all suggestions... Thanks, Rich
