What do you use for engraving figures ? Speed of ​​dremela and proxxon 25,000 rpm  is too small to controlled accuracy grinding !
I found this?
Engraving SCM 400xs engraver SCM’s high-speed 400,000 rpm handpiece gives you a smooth and controlled cut, through the entire operating range.!
or
Turbo CArver the same as SCM !
What do you normally use for engraving figure ?
This unique, ergonomically designed engraver was recently rated the number one high-speed engraver on the market today.
- 400,000 rpm
- Quiet
- Comfortable
- No in-line oiler
- No vibration.
- Air jets, Ergonomic Design.
The 400xs comes with, training videos, 3 diamond and 2 carbide bits, tubing, stencil paper, on/off switch and written instructions.
NOTE: The 400xs requires an air compressor to operate. It requires 1 cfm at 45 psi. A small compressor 3/4 HP or larger will work just fine.
if someone has this device or a similar brand ??????????
