The tender is part of the Artesania Latina BELEM 1:75 kit.
While this build is not overly complex the challenges will be with component sizes (for me anyway).
Moderators, if this topic is not suitable for a build log, please delete.
Photo from the AL website
The frames are mounted on a strong-back for the planking process.  A keel and some 0.45mm planks complete the parts list.
Tender02.thumb.JPG.40507dee15a07df225e928e0a28a0e93.JPG   Tender03.thumb.JPG.2ec21fd0e16d5611f3282ff68e615697.JPG
With the planking complete I have removed the hull from the strong back. The strong back was slowly whittled away to release the hull as gently as possible.  I then put thin CA on the frames where the plywood had fractured from the cutting action.
Next step will be using the dremel to cleanup to hull and frames.
I think I am now past the point of a major accident destroying the hull.
The hull weighs 2 grams or 0.07 oz.
