Hello, I'm new to this site and a m having a minor problem following the instructions. It doesn't seem to state when varnishing is needs to be done. Can any help me.
Thank you
Al Sieffert, welcome aboard.
I would say based on my experience is get the deck done, planking done. Paint if you are painting anything, and then varnish the deck and hull. Then as you go, varnish any deck furniture and accessories, etc.
I would also check any build logs in progress or complete to see when they were at the point of varnishing as well. That may give you a better idea as to when.
Also, start a build log so we can follow along and give advice when needed.
Edited by SKID
Kevin
Current Build
AL Constellation
Completed Builds
AL Swift
hello Al
i varnished the lower 2 decks after adding the rooms. i marked out where anything need to go and drilled some holes they give more grip when gleuing them to the deck
for the top one i am waiting til i have the furniture inplaces as they are too small to use this method
Current builds : HMS Bounty, Constructo Pilar
Next build : undecided
On the Shelf : AL San Juan, Mamoli HMS Victory
Builds on hold : Ochre Gorch Fock, Hachette/Amati Black Pearl
Previous Builds Gallery : Virginia; King of Mississippi
Previous Builds logs : AL King of Mississippi 1/80
