I'm guessing it was just a tad too cold when I painted my hull... I used an airbrush and the acrylic paint that I got from model -expo. The paint is still tacky after 48 hours so I want to remove it. Preferably without sanding. Acetone nor Jasco stripper work very well...
Norwegian Sailing Pram 1:12 Scale. 2nd boat in the learning series.
In Dry Dock:
Muscongus Bay Lobster Smack. 1:24 scale. Model Shipways, 3rd in the learning series.
Not sure what'll be next, probably the Santa Maria by Artesania Latina 1:65 scale. Unless someone has a better suggestion for a beginner.
Pride of Baltimore. Model Shipways. Clipper used in the war of 1812.
Black Falcon. Mantua Model. 18 century corsair brig.
CSS. Alabama. E. Manolie? Can't read the font. Build in Liverpool in 1862 for use in the American Civil War by the Confederates. Steam and sail, sloop of war.
Of all the things I've lost, I miss my mind the most.
A baseball cap my Dad wore.
Great, thanks. think it'll dissolve wood filler?
In Dry Dock:
It's now been 3 days. I've fired up 2 propane heaters. 'Sides. Like I said. Already tried with 2 different mediums. Already into it. I'm sanding it off, clogging a lot of sandpaper, but it's the nooks and cranny's that worry me.
In Dry Dock:
Use isopropanol 90% None of the other solvents mentioned will work on acrylic waterborne paints. Do not apply water borne paints below 45 degrees. Suggest you try either Valejo or Tamiya acrylics
Best
Jaxboat B)
