Barbara
Everything posted by Barbara
  1. I am looking for some steps and instruction for making rolled hammocks for the Bluejacket Kearsarge model.any advice would be appreciated. thanks, Barbara
  2. Sorry I didn’t reply.yes that was helpful I am researching to see if I will proceed. thank you
  3. I am pondering a large scale America kit, does anyone have an assessment of the contents and instructions of either the BlueJacket Shipcrafters or Model Shipways kits? How do the two kits compare? Also do the frames in the BlueJacket kit fit into a laser cot sub deck like plank-on-bulkhead construction ? Thanks, Barbara
  4. Does anyone have a clear diagram of the rigging of the blocks and belaying point for the four 32 lb cannons on Kearsarge? thanks, Barbara
  5. Does anyone know how to rig a becket on the bluejacket double block? They are pretty small, thanks, Barbara
  6. Does anyone have a clear drawing or photo of the bilge pump assembly as my instruction book diagram is of poor. quality. thanks,Barbara
  7. Does anyone have experience with the photo cd for this kit ? thanks Barbara
  8. George are you going to continue your log, I. Will. Follow your lead as I did on the. Flying fish thanks , BarbRa
  9. What is the preferred knot to attach ratlines? thanks , Barb
  10. I am building the modelshipways flying fish and am having trouble finding the lower mast heights and dimensions from the plans. I have built other modelshipways kits and they showed three separate parts. I can’t locate them on the. Plans. thanks for. Your help, Barb
  11. I am looking for suggestions for connecting the deadeye to the chain plate, thank you , Barb
  12. Yes ,I am. Looking for a hand held power device, like a dremel but able to take small bits
  13. I am a ship modeler looking for a recomendation for a good portable drill for use with small bits on both wood and brass, thank you, Barb
  14. I am. Having trouble figuring the main mizzenmast and forward. Mast lengths from the plans, and putting it at scale length, I would appreciate any input
  15. Thank you ,I can not locate the futtock band in the parts ,I have the span collar and hinge, thanks for your help
  16. Can anyone help me with tthe main truss rigging on Charles morgan. Model expo? Thanks
  17. How do you rig the double mainstay on Charles Morgan…? Thanks
  18. Does anyone have a clear diagram or photo for the steering gear and rigging on the Charles F Morgan on the modelshipways. kit ? Thank you
  19. Friends, is there a tutorial on plating? Thanks,Baerb
  20. What is a good way to paint the ship ways to make them look weathered? Thanks
  21. Can anyone make a recommendation for a minwax stain color for my pride of baltimore model expo kit ? thanks. Barb
  22. What plank width should I use for belt a and b the 3/16 looks too wide for the tick marks on my planking layout. I am planking the model shipway kit pride of baltimore . Thanks barb
  23. I am about to begin the model shipways pride of Baltimore, can anyone recommend a good build log to follow? Thanks Barbara
