Hostez
Everything posted by Hostez
  1. I also uploaded a compilation video, on the progress of my cutty sark. https://www.youtube.com/channel/UCCQaWPmASMGVXQIBkXrfEXw
  2. Coppering in progress, i quite like the process. Its not tape, I'm laying one tile after the other. Using the plates delivered with the kit.
  3. Next i cut out the water hatches. To determine the exact location on the hull i drew a side view of the hull on see trough paper and held it against the ship. then i marked the four corners of every hatch and drilled out most of the wood. making the frames square with a file.
  4. Next i painted the inboard side of the bulwarks in mat white. I painted this first before laying the deck planks, that way i dont damage the planks with tape. Also i wanted to paint first before cutting out the water escape hatches again to avoid having to apply masking tape to the outer black hull. Its the first time i used an airbrush for painting, it was getting used to to control the correct flow but it turned out quite well. So next i will cut out the hatches. While im still pressing down those rivets in the copper plates
  5. Your copper tape looks good Rob! And indeed much faster. Maybe for a next build in the future I was not such a fan of tape because most of the time you can see its tape and not real plates. Tape tends to rinkle. But your method seems to work out just fine. I guess your tape is thicker than what some other people use.
  6. I Hammered some copper plates, now they look more like imprinted nails. The tiles on the left are pre hammering, the ones on the right post hammering. Looks more like the real thing that way.
  7. Im glad you told me before i glued them on, indeed lets make it look more like the real ship
  8. Thank you for your advice Rob, I will see if i can hammer those rivet heads down in between two metal plates, so they look more like nails.
  9. These are the copper plates im going to use, im going to test some tiles with burnishing fluid to see how it looks good with some weathering. How would you guys prefer it? Clean polished copper or weathered?
  10. Hi Johnny, in this picture you see more in detail the copper plates after polishing where the nails are visible. I got a full set of clinkered pre cut copper plates with my kit. They look realistic so im going to use those.
  11. So! Time for another update. When i looked at old pictures of the real ship when she was still in service i saw that on the waterline and below it there were two strips guiding the copper plates. So i added those too after marking the waterline. These strips were cut from strips of deck planking and cut to shape. After having a final check on the hull i applied pitch black alcohol ink to paint the hull black instead of real paint. That way the wooden planking is still visible. This i will protect with shellac later on. Nxt step is installing the copper plates. That will be a new adventure Just doubting if i will weather the copper plates using burnishing fluid or leave them fresh.
  12. And finally she is fully planked and sanded. Quite a milestone for me on this project. Next is removing the frame tops and drilling out the water drain doors. Then i will paint the hull black and add the copper plates.
  13. In the meantime, our son is born, im getting back at my cutty => LH side second planking completed, RH side only bottom half still to do
  14. Thank you Johnny and Scott for the encouraging comments. Here's my progress with the second planking so far:
  15. SO! Now the ship is ready for the second planking:
  16. I had to redo this process several times, applying putty, drying, sanding, reapplying putty, drying sanding... untill i was happy with the results.
