jfesterman
Everything posted by jfesterman
  1. The instruction booklet was the only thing I could find on AL's website. https://artesanialatina.net/en/index.php?controller=attachment&id_attachment=221
  2. I’ll see what I have. Scanning and posting while maintaining scale, might be a trick, but if I have them, I’ll give it a go.
  3. The workshop re-arrange and de-LEGOfication continues.  Someday I’ll get back to modeling.  Why do they leave all the LEGO when they move out?
  4. Sorry folks, Hannah is on hold for a while. Thanks for sticking with me, as you all know hobbies can take a back seat to life sometimes. I’m ok, everything is good, I just had to dismantle part of the shipyard to concentrate on a different mission. I hope to get back to it soon.
  5. More progress today. Yards and bowsprit are done. Pretty soon, I’m going run out of these little things and then I’ll actually have to paint the hull…
  6. J Brent’s videos on YouTube made rigging the spars much easier today. Not sure if that fella’s still with us, but man, he pulled me out of a dark place. Much of the frustration of yesterday had to do with threading those little parrels. Pick one up, drop it, pick it up, five times. Pick up another and pew! Gone forever. Still, I think I only lost 2.
  7. Rigging blocks and stuff on the spars was getting really frustrating today. Had to walk away.
  8. Well, the 6 mm stock was no match for the jig. I snapped the main boom twice! Good news is, with a furled sail on it, you’ll never see the repairs. Shorter lengths of the 6 mm stock faired better, like the jib boom, gaffs and mast tops. I ended up shaping the 4 mm stock mostly by hand. The lower fore yard will just have to be about a cm short… don’t tell anyone. I’m glad I made the sanding blocks anyway, they came in handy even for hand shaping.
  9. Prototype 1 of dowel tapering jig. Two one-by boards with 80 grit adhered w/ spray adhesive. Main and fore masts are 10 mm and need to taper to 6 mm over a 30mm (or so) span.. Block at the top is 6 mm, block at the bottom is 10 mm. Chuck in the drill and SLOWLY run it through until it comes out the other end. I made a shorter version for the spars. The original vision in my head was something more permanent, affixed to a plank, with carriage bolts and wing nuts, etc. Would have been way more complicated and required a trip to the hardware store. So far, working fine. Unfortunately, it’s really noisy and my son’s trying to sleep in the next room. Maybe I’ll wait a little while to finish these up. Nah… Side note, I had this idea before I found a similar example in another MSW forum, which used paint stirring sticks, which in my opinion, might work ok for spars, but definitely not strong enough for these bokapi (?) masts. His original idea was linked in his post to a Polish model ship building forum. Here it is:
  10. Deck mock-up. Good thing I did this! In full Adam Savage mode, “am I missing a fife-rail?” I’ll get right on that…
  11. https://www.ebay.com/itm/293563503023?hash=item4459bf91af:g:K6AAAOSwHmNZvHEl
  12. I’m not super happy with it, but the rudder is mounted. Definitely tired of fiddling around with it! Catsheads, hawse holes, and belaying pin racks installed. Mast holes too. Planning a dowel tapering jig. When I have a working prototype, I’ll post some photos.
  13. Rails, wales, davits, prow heads, cutwater reinforcements, outboard channels.
  14. Tried my hand at making some blocks today. 1st try above, loop a little too long (too many twists)? Anyone have any better ideas for these?
  15. Making more progress. Mounted stem, keel, and rudder post. Drilled holes for bowsprit and rudder. Cut cannon ports and framed them. Installed bulwark stanchions, breast plate, and stern belaying pin rail. Bending up the hand rails. I also constructed the rudder and hinges, all ready to go. I made sure the rudder would be removable for now.
  16. Ok, so here’s the thing… I know this is technically wrong, but I will be painting this hull. That said, working with these .5mm walnut strips is challenging. Unless they are cut very thin, like half a plank or less, they absolutely will not edge set without splintering or twisting up. They’re also very hard to thickness plane in long lengths. I opted to go with an easier, more natural lay, using more of a “magic line” approach, rather than an extra amount of spiling and stealers. I ended up with one small section just under the shear where there’s an odd shaped filler plank, which still manages to get to full thickness in the middle, but tapers way more than is acceptable.
  17. Bilge pump and bucket shelf. Modified the bilge pump design a bit and used wire for bucket handles, because none of the line included in the kit seemed to be the right scale for rope bucket handles. When it comes rigging time, I might source all new line. I’m not happy with the looks of this stuff.
  18. Yes, I made the gratings the same size. Upon a more thorough examination of the instructions and plans, the forward one is supposed to be a bit smaller. Might fix it later.
