Hi druxey,
Steel refers precisely to the "stops" of the ports to be not less than 3 1/2 inches !
When the lining is the inner layer of the port lid, so why does Steel refers them also precisely to the stops and not to the
half port lids (for example) on the upper deck in smaller ships later ? There, the lining is mentioned in combination with the deal boards of the lids and is written in separated brackets.
Hi writes: "linings fitted into the stops" - so the linings belonging to the stops and not to the lid, correct ???
So, when the lining is fitted into the stops, how does this arrangement looked like in the ports ?
Where were these 3 1/2 inches (minimum) thick pieces installed and where the linings of 1 1/4 inches ?
Could it be, that the stops were put on the sides of the port (frames) and the lining on the upper and lower sills ?
This would give the port a nearly square form and, reducing the width of an 39 inches wide port to 32 inches is not as dramatic, as installing this arragement different.
The problem was and is the heavy pieces that Steel refers to as the STOPS !
When you say, that these stops were fitted into the ports and the lining is the inner layer of the port lids, so the ports themselfes would be reduced to: 26 inches in depth to 32 inches in width ?! This reduction would have been notably visible by looking at the ports. These wide edges would have caused a problem to the handling of the gun barrel, at least for the width up and down ! Also it would have been strikingly visible at models. Here the lining of thinner dimensions is clearly visible and coherent. So the lining (as is your opinion) of 1 1/4 inches thick plank, would make sense and a perfect match. (See models in the NMM as Bellona for example)
What is right now, what is wrong ? What did Steel mean ? Can it be, that this is arranged like in the picture above ?
At least this would make sense ! Where else could such a massive piece be installed without being clearly visible,
2 1/4 inches bigger than the lining ???
Greets, Tom
