hubacekn
Posts posted by hubacekn
On 29. 9. 2016 at 6:52 PM, Beef Wellington said:
Think I've got a bit of catching up to do. Firstly, heres the Captain Cook Monument in Waimea, no undercooked beef wellington shots in this one
. Found the beach he landed at, nothing special but couldn't locate the plaque that allegedly marks the spot according to guide books.
I have managed at least an interim milestone, the completion of the starboard copper...this task just goes on and on
Couple of items I've found to be helpful:
- Super Solvent - I've found this product to be highly effective at getting rid of any CA glue residue (at least the Admiralty Pro thick stuff). Wiping over the surface of any potential smearing is usually enough
- Some plates plates require very acute angles to be cut and when using scissors (which I find by far the easiest), the ends tend to curl and distort horribly. I found that cutting these as part of a larger section this problem is eliminated, although care is needed still to separate them.
And the results. Some of the photos are before I cleaned to plates with copper cleaner, which I did to ensure that there was no CA residue anywhere. These will need to be done again once all the plates are on as I can guarantee more finger prints. Managed to do the copper plate pattern at the bow that seems to be prevalent on so many models and AOTS drafts, slight discrepancies in the plates will only become less noticeable as the copper ages and darkens. Overall I'm very happy with the Amati plates, and slight plate misalignments that just seem to be inevitable when using CA glue are tolerable. Not sure I could do it any better if I were to do it again, so I think that's the yardstick to meaure to.
At the bow, I plated the cutwater first and tried to shape the plates on the planking to match the required curve. Its far from perfect but will do. I think these areas are inherently limited given the thickness of the plates, I suspect using copper tape would allow a more scale appearance.
I drilled some small holes in the waterline batten to simulate nails and highlighted with pencil, these are not to scale but felt it gives it a little bit more functional relevance.
Et voila! The pinkish hue of freshly cleaned copper reminded me on the AOTS Diana picture, I was very pleased with the lines that appear once the waterline is apparent. Obviously next step is to continue with the other side....
Dear Jason,
i would like ask you from what material you made waterline...?
I made copper shield on my HMS Pegasus and i dont know, how to and what to do waterline.
Thank you a lot
Michal
HMS Jason by Beef Wellington - Caldercraft - 1:64 - Artois-class frigate modified from HMS Diana 1794
Dear Jason,
than you very much for your tips and advice!Its very helpfull for me.
Michal
