Posts posted by Gentlegiant
Thank You Captain A.L.
Thomas tank for the level it's another good idea
Ulises O.K i have metal square and some spring clamps thank you this is really clear with the photo.
i can glue the frame and fit all wen i put the lower deck very interesting Thanks
Captain AL , if i understand you use three planks for the lenght of the hull , this is interesting.
Tank you for the advise of matching the open ended planking , this is an other challenge too.
If i use single planking can i use 1mm plank or 1.5 ?
- Dimitris71 and mattsayers148
- 2
Hello all the Bounty builders , i follow all your build log. I foud full good idea in all the different build log for building mine.Last week i check the instructions and the parts , and i have a question about the single planking with the 2mm thick walnut .Watt do you think off double planking with two kind off strip more thin ?
Hello Jack This is my first model and i know nothing about the wood . Can you give me the list of the wood you buy for make this model . (On the 2 January photos ) Thank You
Gentlegiant
Bounty by Gentlegiant - Artesania Latina
a photocopie of the plan x 3.714 give just the good scale for trace it on a 1.5mm plywood. It will take a copier with the possibilite of print the copie x 3.714 . I don't know if it 371%.
