HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
sob
Everything posted by sob
  1. I could list 50 other sources but if you will not accept them there is no point
  2. also page 57 of https://www.dieselduck.info/historical/06 books/1980 - The Seafarers - The clipper ships.pdf
  3. see, for example https://landandseacollection.com/id267.html also from https://www.busaccagallery.com/gallery_view.php?id=6292&page=video "McKay had learned his lessons well in the construction of water-line half-hull models from the master, Orlando B. Merrill, from his earlier days at Newburyport. Once he was satisfied with his workmanship, he removed the dowels and the rectangular slices of wood, known as "lifts," and one by one transferred the lines of each "layer" of the hull to graph paper called a "sheer plan" by maritime architects. The scale ratio translated out to one quarter of an inch for each foot of the ship, 48 times the original length of the lines. The lines were now ready to be transferred to McKay's huge mold loft that was the size of a ship. It was here that a full side of the Flying Cloud was charted in chalk with a different color of chalk used for each lift layer. The shape of each lift edge's chalkline on the mold loft floor showed the exact water lines of the hull at various depths. With his keen attentive mind and trained eye, Donald McKay had no trouble visualizing his one dimensional colored chalk lines of the Flying Cloud's three-dimensional hull." many other references
  4. I read that it was the other way around - the half hull was the master and the lofts were done from that Scott
  5. its not over the length - only from about the foremast forward - so even less the difference in angles also was not the same between ships
  6. re: "Crothers' statement that decks were kept level " he actually said that the deck rose at a slower rate than the planksheer - not that it was flat if it were flat the would be close to 3 feet of extra space at the forecastle - my plotting of the sheer against the deck & planksheer came up with around bit more than 2 feet of extra height which worked out to enough without a lower floor but a lowered floor would have made things far more comfortable Scott
  7. simply I do not have any documentation that this artist was at that location at the right time - I have no reason to think that he was not but can not vouch for the drawing unless that information comes up - at this point I assume he was Scott
  8. we are after the same thing - historical accuracy - but that is, in reality, unobtainable since the records do not exist - all we can do is to do our best and that may mean that we do not all agree on every detail among other things you have concluded that there was a step down under the forecastle - based on Crothers I do not think that was needed you have concluded the the windless was huge and under the forecastle - that is an uncommon view and with so many sources saying that the windlass in that time period was generally aft of the forecastle I tend to the other view you have concluded that the structure on the glory (that looks like a headboard) had a purpose far more than to just looking good - I have no reason to think otherwise and do not have an opinion on the topic but you extend that conclusion across the entire McKay line of clippers and I see insufficient support for that extension I will be updating my drawing based on our discussions but not likely to your satisfaction I'm not sure there is more to be said that would convince me or you of the correctness of the other's ways so maybe its time to let it go as it is and focus on what we agree on unless more information comes up to settle the questions Scott
  9. note - excerpt from Crothers I posted a while ago says that the sheer of the deck did not follow the sheer of (for example) the main rail - in fact the distance from the deck to the main rail grew as you got closer to the bow thus giving additional headroom under the forecastle without the need to have a step down
  10. here is what he said in his manuscript - he later tracked down the original Captains of ships operating in the China trade often commissioned a Chinese artist to paint their ship while it lay in Hong Kong or another Chinese port. It was the practice of these Chinese artists to go on board and actually measure the various features of the ship, after which they would return to their canvas and meticulously lay out the ship as a sheer or broadside plan. They painted using these lines as the skeleton. Because they were for the Captain, and because actual measurements were taken, paintings of this type were considered to very accurately represent a ship. The Peabody Museum has in its files a very small (3” x 5"), stained photograph of one such painting which is labeled as the Flying Cloud. "Old Ships of New England" reproduces the same painting, but it appears to be simply a photograph of the Peabody photograph. However, there is some question of this being in fact a painting of the Flying Cloud since the steve of the bowsprit is 5½ inches versus 4 inches shown on the MIT plan and in the Currier lithograph. At tempts to locate the original painting have failed, but careful examination of the original photograph under a microscope did not disclose the name of the ship. The assumption has been made that this painting was actually of the Flying Cloud and it has been used to a considerable extent in this study.
  11. only what he wrote in his manuscript https://www.sobco.com/ship_model/fc/Lane/Flying_Cloud.htm
  12. yup - that copy is from the book on the FC's first passengers I tried pointing the Peabody Museum at the owner but never heard anything back Bruce Lane said he saw the painting in the owner's house and said it was quite faded Scott
  13. yes, this is one of the paintings that I think may have been done from life (the timing is right but I'm not sure the artist was in the right place at the right time) - it is a very nice painting - though hard to see the details at this scale - someday I'd like to see the original
  14. I did find one in a book by Rob Napier - Caring for Ship Models (highly recommended) - can not see the top but still very impressive visually
  15. Rob said: if you have any pictures of those other models, I'd love to see them. I've seen pictures & have seen one of the models (an America's cup type craft) but do not have any myself and I do not see any on-line
  16. well, common wisdom is sometimes (but far from always) wisdom one other citation about headboards - this time from Campbell in his China Tea CLippers McKay's clippers, although keeping to the clean bow as on the later New Yorkers, tended to retain a longer stem knee and featured a form of decorative headboard which was built flush with the hull without exposed timber supports, and looked very handsome.
  17. double acting captains can have different gearing on the two rows - straight or through planetary gears giving more torque see: https://www.sobco.com/ship_model/fc/details/capstans.htm as for the model - next up is the poop rail (lots of stanchions mounted at an inward angle) then the made-masts - then (finally) rigging - I've done a lot of research on ropes see; https://www.sobco.com/ship_model/articles/Obsessing_about_rope.html so I'm ready (my own rope walk as well) when the time comes
  18. a while back I mentioned the sheer needed stop be taken into account when talking about the height under the forecastle - I recalled a discussion of test in some book & just found it in Crothers - page 40 The sheer of the weather deck, as quoted in various descriptions, did not necessarily run parallel with the sheerline of the planksheer (also called the covering board), and the main rail, the latter two generally, but not always, being parallel with each other. The deck sheer followed the trace of the planksheer from the stern through the length of the vessel to a point approximately abreast of the foremast. At this point, in ships where the two sheerlines diverged, the deck rose at a much flatter and slower rate than did the sheer of the covering board and main rail. This divergence accomplished two objectives. First, a deck with the same steep incline as the covering board would, in many vessels, require a seaman to constantly walk up and down hill when working the forward end of the ship if she was sailing in normal trim. The situation would be exacerbated if she were trimmed by the stern. This of itself would not be very practical, and practicality was part and parcel of shipbuilding. The second result was that of achieving headroom under the topgallant forecastle deck. This allowed for housing one watch of the crew, handling of ground tackle, installation of the anchor windlass, and location of the hawseholes totally above the weather deck, a very practical accomplishment. Sufficient headroom beneath the topgallant forecastle deck was required, as it was an important working area. with a sheer of 3 feet the FC would have quite a bit of extra headspace under the forecastle (as noted in the Crothers diagram where he says the headspace was 6 4" - quite enough when the average height of a full grown mail was about 5 1/2 feet)
  19. ps - this is what Crothers has for the forecastle plan for the Flying Cloud note he has windlass behind the deck & in another drawing shows a capstan on the forecastle
  20. Rob Asked: Some things to question. First: you have built a very beautiful model here Scott. Is she scratch or from a kit? I see you have the patent ventilator and the straight pipe ventilator within the stanchions and planksheer. What I do question is, why on earth would the chain be ladled across the open deck, to be a tripping hazard, and destructive to the deck? From what I gathered, and which makes greater sense, is to run the chain straight down from the patented windless (as outlined elsewhere), and guide the chain in a chain trough (as would be expected in the forecastle)...down to the chain hold? It is said, no scientific application was speared, and the utmost attention was paid to her construction. I see you have added the double action patented capstan....but what function does it perform if not coupled to the patented windless below? thanks, the model is fully scratch (and from my plans) - I did not grow the trees, smelt the metal or forge the chain but I made everything else (my previous FC hull was from a kit but I tossed everything but the bulkheads) re: What I do question is, why on earth would the chain be ladled across the open deck, to be a tripping hazard, and destructive to the deck? I did it that way because 100% of the plans and drawings and models of the flying cloud and almost all other clipper ships have it that way - and, in addition for balance it makes more sense to stow the heavy chain further back in the hull (where there is also more space in the hull) - the White drawings of the FC deck do show a chafing plate under the chain but no other clipper ship plan does re: but what function does it perform if not coupled to the patented windless below? as I've pointed out, all of the other FC plans & models and those of almost all other clipper ships show the windlass aft of the forecastle and many also show a capstan on the forecastle as for use: docking, fore lower sail, jib sails ...
  21. I got to wondering if people who spent the careers studying ships said anything about the structure you point to on the Glory the first ting I found is fro Crothers' The American Built Clipper Ship 1850-1856 (1977) - this is the go-to book for most things clipper ship this is figure 24.2 it looks a lot like the Glory structure sad to say, the book does not include the Glory so I cannot be sure in any case, Crothers does not think much of the structure he calls a "headboard" but he does list a number of ships that had headboards (p 361-368) some of what he says: Between 1850 and 1856, the bows of the clippers generally became plainer as each year went by. The cumbersome headboards, which were subject to destruction at sea, and the graceful trailboards, with their expensive carvings, were diminished for pragmatic reasons, as described in Chapter 24.as described in Chapter 24. Headboards The headboards, illustrated in Figure 24.2, were the only exterior planking remaining to be fitted in the ship. They did not constitute a part of the structural hull, even though, due to their exposed position on the bows, they required sufficient substance to enable them to withstand the heavy battering of rough seas. Their structure, stoutly supported by transverse timbers called cheeks, which were anchored into the stemhead, was heavy and cumbersome, even though their appearance to an observer was graceful and pleasing. They served no purpose other than to ornament the bow and render the forward endings of the planksheer and the main rail more pleasing to the eye. In general, the upper rail projected forward in a line which continued fair with the sheer of the main rail while the lower rail continued as an extension of the planksheer, sweeping forward and upward in a graceful curve until the two rails converged immediately abaft the figurehead. Between these rails, the transverse cheek timbers supported suitable framing to which the headboarding was fastened. Detailed information on the subject of headrails and headboards in merchant vessels is very scarce and difficult to find. This, as is the case with much intimate detail concerning commercial ships, is due to the fact that, in early days, such ships were constructed as individual enterprises. There were no precise rules in place, so each shipbuilder followed his own initiative and inclination. With no central policy or control, it was inevitable that there would be great variation of detail among merchantmen. However, the general rules of construction were followed by all shipbuilders and thus, at any given period, all ships being built were constructed in a like manner and they all took on the same general appearance, adhering to the same general details. ... About the year 1815 a new feature appeared at the ship's head, namely headboards. A new straight rail, uniformly tapered from its after end to the forward end, was installed between the catheads and the figurehead. The space between this new rail and the old upper rail was boarded in. This detail is very apparent in the United States ship of the line Columbus. The ship's head had finally received a very small improvement. By 1840 the old individual, graceful headrails were superseded by more predominant boarding. The topmost rail was an extension of the main rail and the lower rail was an extension of the planksheer. By this time, foremasts were located abaft the forecastle and the ship's head was moved under cover. In 1850, headboards were regularly built into the bows of large merchant vessels. However, it was a time when shipbuilders and owners, pressed by demand and economics, looked for ways to speed construction and reduce costs without sacrificing a ship's seaworthiness. By decreasing the structural work required to install headboards, they saved both weight and labor, which, along with the elimination of excessive and useless structure, fitted nobly into the design of the dipper ship. And so began the demise of headboards, particularly in dippers. Of the vessels included in this book, only twentytwo are definitely known to have been built with headboards. Between 1851 and 1853 the number of ships built with headboards declined uniformly until they disappeared entirely. After 1853 the only dipper ship built with headboards and included in this list was Noonday, launched August 25, 1855. (he says much more) since he does not list any McKay ship as having headboards this may not be related to the structure on the glory but it does look basically the same McLean mentions a few ships with headboards so he know the concept (Shooting Star, Antelope, & Silver Star) maybe, if ay did come up with a strengthening structure he used the old headboard design as a cover Scott
  22. ps the Boucher models were made for show & impact (and that they have) - Boucher had a factory in NYC that made models and accurate detail was not one of their hallmarks - but they sure do look nice (their are some more of his models - full sales and all - in the NY Yacht Club
  23. ps - few of the paintings of the Flying Cloud (and many early clippers) were likely done by artists who had actually seen the ship - most artists went by whatever descriptions they had (e.g. the McLean articles) and by what they knew about clippers in general there were some of the Flying Cloud where the artist might have - see https://www.sobco.com/ship_model/fc/what_Flying_Cloud_looked_like.htm
  24. basically we are just like the plan makers of the 1930s - we do not have access to any actual plans and we do the best we can with what info we have that means, by definition, we (all of the people looking at the design of a long-ago ship) will not agree on every detail it would be great if some long lost photos of early clippers showed up with enough detail to resolve some of these questions but, if we are to go ahead and build something we cannot wait for that chance Scott
