cgiacoppo
NRG Member-
Everything posted by cgiacoppo
It was difficult to get the chain back through the hole. I ended up tying a piece of thread to the chain and then the other end of the thread to a piece of thin wire that I was able to push through. Once the end of the wire emerged with the thread, I used the thread to pull the chain through.
- 37 replies
- first build
- BlueJacket Shipcrafters
We now turned our attention to the holes where the rudder chains emerge from the hull. We previously used cardstock to create the armor plate rub rail and decided to create semi-circular openings out of the same card stock to give the holes a nice finished look.
- 37 replies
- first build
Setting aside the deck planking, we next attached the pilot turret. This is a metal piece so we used 2-part epoxy. The lookout ports on the turret were very slight indentations, so we drilled them out a bit to make them more realistic.
- 37 replies
- first build
- 37 replies
- first build
Once the decking was shaped to fit the top of the hull, we needed a margin plank. We photocopied the decking and used two-sided tape to attach strips of veneer to the edges of the copy so we could cut it out without damaging the planking.
- 37 replies
- first build
Thank you Robert Chenoweth and Phil for your tips. Well, we didn't like the way the last the last adjustment looked so we removed it. Unfortunately, I was a little over-vigorous with the sander and it distorted the top of the hull. My fault. I repaired it with some wood strips. The hope is this will mostly be hidden when we paint. Next we decided to plank the top of the hull using a thinner piece of pre-scribed veneer. I purchased such a piece but decided the plank lines were too close to each other. So we flipped it over, marked new plank lines with a pencil to simulate caulking, and then scored those lines with the back of a putty knife. We taped a copy of the plan over it to get the shape and cut it out. We sanded the back to make the veneer as thin as possible. Set on the model before final sanding.
- 37 replies
- first build
We cut out a thin piece of wood to serve as the top of the ship, in the hope of getting a sharp edge between the top and the sides. It has been glued and clamped in place. Once the glue dries, we'll remove the clamps and see if any patch work is needed to create a clean, sharp transition from the sides to the top.
- 37 replies
- first build
Notice the copper plating along the keel in the previous 2 images. This is difficult at this scale, requiring a 1/16" strip of copper foil. The smallest we could find was 3/16" so I am slicing them in half (not easy!). At this scale, we decided to leave out the nail pattern. This was a test strip and we were pleased with the result. We will continue this once further progress on the model is made.
- 37 replies
- first build
The wooden strip turned out to be too inflexible and difficult to work with so we replaced it with a cardstock strip as suggested by the kit instructions.
- 37 replies
- first build
- 37 replies
- first build
- 37 replies
- first build
Fantail installed. The chain used to move the rudder is temporarily in place to make sure we could install it with the deck in place.
- 37 replies
- first build
While Michael worked on the rudder, I used some leftover strips from another kit to straighten the keel and stern post.
- 37 replies
- first build
Pintles & gudgeons are not part of the kit. At 1/16 scale, we'll keep it simple. Hat tip to jre8655 and his post from 2013 - we will use a similar technique. Michael drilled holes with a #74 drill and glued in 4 pieces of brass wire. These will be used to connect the rudder to the post and should be concealed when complete.
- 37 replies
- first build
The new template fit perfectly and was attached to wood stock with two-sided tape and cut out, filed clean and then the post was separated from the rudder.
- 37 replies
- first build
- 37 replies
- first build
The rudder as depicted on the plans is too small for the area between the fantail and the keel, so we did a bit of math and determined a 12% increase in size would correct the problem.
- 37 replies
- first build
After another long break Michael is returning to this model. During the break, he built the frame of the Chuck Passaro English Pinnace that he was given as a gift, and completed a model of USS Laffey DD-459, which took 1st place in the Junior division at the 40th annual NE Joint Clubs Ship Model Conference on April 29th in New London, CT. New pictures to this build log coming soon.
- 37 replies
- first build
A gap between the keel and the hull at the stern will be filled with scrap wood strips and then finished with wood filler.
- 37 replies
- first build
- 37 replies
- first build
- 37 replies
- first build
Installing the stem. Some building up of the hull with thin wood strips was required to get an appropriate fit. This will all be covered up when the copper plating is installed.
- 37 replies
- first build
- 37 replies
- first build
- 37 replies
- first build
- 37 replies
- first build
