dj.bobo
Everything posted by dj.bobo
  1. Good evening for everyone. Things go slower due to small pieces. For now turnbaker tensioner. A beautiful evening still I want you. Adrian
  2. Good evening to everyone, today I will continue building with an important and shiny work named railings . A beautiful evening still I want you . Adrian .
  3. kees de mol , jim lad and michael mott , thank you . Adrian ,
  4. Good evening for everyone, work continues with a few parts called drogue failead end stowed anchor . All handmade made of styrene and brass. All the best and a beautiful evening. Adrian.
  5. Hello everybody, today we've finished two more parts on my model and I'm called boat hook . I also worked with metal, my favorite brass with copper wire. Because I am in the end of building I will make a list of what I have to do. Have a beautiful night. Adrian.
  6. Good night for everyone, work continues with the radar of the ship. After eight hours of work it came out like that. For making it I used a kind of styrene that I stuck in several layers and the brass plate. All the best . Adrian .
  7. Good evening for everyone, work continues with the end of the forward vent pipe with the fastening of the last screws and we continued with the construction of the railing in the aft and bow. A beautiful evening still I want you. Adrian
  8. Good evening for everyone, because I'm working on a generous scale today I've built the welding cord on the side. For this we used styrene profiles, plastruct 90879. The size of the semi-round profiles is 0.8 mm. A beautiful evening still I want you. Adrian .
  9. Good evening for everyone, work continues with the survival coils and the anchors of the ship. This time we worked on these styles in styrene and ABS. A beautiful evening I still want you. Adrian.
  10. Good evening for everyone, for now two more ready pieces, namely sailing lanterns and the ship's capstan. I was working on a lathe with linden wood and a few pieces of styrene. A beautiful evening I still want you. Adrian.
  11. Good morning to everyone, the work continues with a few tracks from the ship's bonding facility mooring bollard and quarter bollard , And one piece at the ventilation installation extractor vent . Everything worked in brass and copper wire. Have a nice day . Adrian.
  12. Good evening for everyone, for today we've worked the ship's antennae. The whole construction was made of brass pipes and brass profiles, which is difficult because of the small size of a few pieces but in the end we finished well. A beautiful evening still. Adrian
  13. Thanks for appreciating druxei, trying to do the best is a model of training, after it you follow a great project. All the best and a beautiful evening. Adrian
  14. Thanks for appreciating Patrick , on the scale I'm working on , I'm forced to do all the details, even the money in the captain's pocket. All the best . Adrian
  15. Good evening for everyone. Today we finished the railngs on the command deck. It worked harder because at first I used a 20 watt soldering hammer, then I called heavy artillery and used a 100 watt soldering hammer. All the best and a beautiful evening I wish you. Adrian
  16. Good evening for everyone. The work continues with the exhaust pipes, the construction we made from brass tin everything was tinned and for the hinges we used M1 screws. Finally, the exhausts will be painted in chrome. A beautiful evening still I want you. Adrian
  17. Hello everyone . Work continues with flaps. For this we used copper brass and copper wire. I will use a stretcher for the regiment of the nail. I wish you a good day .
  18. Good evening for everyone. A little work for today. A beautiful evening still will want. Adrian .
  19. druxei, captainbob thanks . Work continues with the construction frames and windows on the upper deck. I made brass frames 2mm square profile that I worked a little. I used the windows tinted ABS 1 mm thick. A beautiful evening still will want. Adrian .
  20. Good evening everyone. Work continues with the completion of the installation wiring Hand mast and complete hydraulic system. I will mast mounted navigation lights , radar antena and serchlights . A beautiful spring evening you want. Cheers Adrian
  21. Good evening everyone. Work continues with some piece mast cylinders hydralic mounting support and an antenna who do not know what good is. A beautiful evening will want next. Cheers Adrian
  22. Good evening everyone. Work continues with a more complex piece, namely the main mast. I used copper wire and brass sheet. Still not ready have worked a lot of parts on the mast. .inc I built a small piece namely engine telegraphs. I wish you a pleasant evening .
  23. Good evening everyone. Continue with two parts, control panel and railing behind the steering head. All the best . Adrian
