marius beltman
  1. Thanks, When I still lived in Cape Town I was a member of the local model ship society there. They suggested an off white color called barley white as the right color for below the waterline.
  2. Members 2 posts Report post (IP: 41.115.13.142) #33 Posted yesterday at 07:53 AM Hi, Just a question about the "gunports". I also wrote to billings, but it does not look like they are going to answer. When I look at the drawing of billings it looks like they have not made gunports, just glued the plastic gunport surrounds on the hull and then drilled a hole in the hull for the guns and maybe just found the piece inside in black to have? But it seems like you have made gunports in the hull. If so, how did you fix the guns? Do you also know what the real color was of the hull below the waterline? It also seems as if the waterline is very low on the drawing, this is correct. If so, I am not surprised that it sank so easily, even if it had not already had the extra cannons on board. If you answer, you can use my regular e-mail. It is cherryberryb40@gmail.com, I look at it every day. Thank you again for the effort, marius beltman.
