Bill Hill
Everything posted by Bill Hill
  1. Thanks for the wonderful insight. After copper sheathing the CW Morgan I think I’m going to paint it copper
  2. Thanks Gregory, much appreciated. I’ll have to pick up the book, sounds like a good read.
  3. I thought that maybe she was Coppered but she was built for speed and coppering would of slowed her down. However anti fowling may have been a bigger priority
  4. What’s a good color or what is the true color for the bottom paint (below waterline) on the America.
  5. When I built the Morgan I was unhappy with the look of plank shear, looked uneven at spots. So I sanded it down and added strip of wood. This has been an approach I saw in a build log. You may want to consider adding a strip of wood to make the same effect.
  6. Great craftsmanship. I’m about to pull the trigger and order the kit so I’ll be a few months behind you and will be referencing your build log quite extensively. Keep up the good work and please keep posting. Much appreciated Bill
  7. When did internally strapped blocks come into use in the US?
  8. At any level they are all a challenge, looks like you toughed it out. Well Done!
  9. When did internally strapped blocks come into use in the US?
  10. I’ve had success with using Birchwood Casey ( gun blueing ) for blackening metal and brass. It takes a little finesse so get some practice pieces. There is some good instruction in the painting portion of this forum.
  11. I’am unable to find the pdf on building the tryworks for the Model Shipways C W Morgan that Gerald Spargo put together. Can anyone who knows where it is at please send me the link and/or location. Thank you, Bill
  12. What is the best method for brass and other metals, paint black or use a blackening agent. I’ve had mixed results with either method.
  13. This is on my list for next build. I appreciate the build log and look forward to view your progress and insight on the build.
  14. Any insight on the best product and method to blacken brass in lieu of painting?
  15. I agree the cyclone pre filter is a must!
  16. Thanks Joe, this is what I’ve been looking for. Bill
  17. I have the Byrnes saw, sander and thickneser and want to hook up a dust collection system. Looking for ideas for a simple system. The connection points seam to be an odd size (1-1/2”?).
  18. If your ripping your lumber on aByrnes saw from good billets or sheets from Syren is a thickness sander a must have to finish it out? Bill
  19. Thanks Bill, I think that it will be my approach also. Did you buy a saw to mill the wood?
  20. Thanks Jim , I’ll check out the book. Sounds like a good ref book regardless. The Cheerful interests me, maybe not as complex as the Winchelsea? Bill
  21. Over the years I’ve modeled several ships from kits. Honoring my skills along the way and still learning. I’m wanting to step into scratch building and am looking for a recommendation on the first project. One of the projects on the NRG site? Something from Syren? Other options? Bill
