david.wait
Everything posted by david.wait
  1. As a new member (4th June 2020) I may be doing this wrong and I apologize if so. I have the above model and, although have read through the instructions and reviewed all the plans, I must admit to be struggling on how you make and fit the the gun port linings. Also how you fix the cannons on the Middle Gun Deck (#22) between bulkheads 14-17 where there is no deck ? Any help or references are much appreciated. regards Dave
  2. Hello, I have some questions relating to the Caldercraft HMS Victory 1:72 model. I have some questions for the experts, which I am not, I have built other ships (Cutty Sark), etc. but I am a little confused on some small but critical points. 1) The instructions suggest that I should fix (glue) the gun port pattern pieces early in construction but if this is done the cannons canot be installed due to the 'dummy barrel strip' as it does not have enough depth for the cannons....? Of am I missing something obvious...? 2) Lining the gun ports - It is clear that you have to build them individually but for the ones dummy cannons on the Lower Deck how should they be supported / fixed in position...? 3) Also related - on the Middle Gun deck which is used to hold the bulkheads in position, between bulkheads 14 - 17 there is no deck where the cannons should go...how do you make / fix the linings and subsequentially the cannons. The instructions are 'vague' in this area. Just to be clear I am in the very early stages an have been through the 'instructions' and the plans to try to ensure I make no mistakes before I progress. Can any modeller help...? Regards David
