Scooter McFly
  1. I think you’re going to like it. I use mine all the time. And not just for modeling 😉. You need two things that will reduce your frustration though because accuracy is not a dremels strong suit. First, get a vice you can attach to the base. That’s what those square holes and grooves are for. Second, get an on/off switch and plug your Dremel into that. You’re going to find that every time you turn it on, it moves. I plug mine into my work bench. Makes life easier. I don’t use it for spars or dowels. It’s useless. I use my lathe or a hand drill for that. But for sanding and drilling, and cutting...it’s great. This is all referring to the stand. Just wanted to make that clear 🥸
