Keith B
Everything posted by Keith B
  1. I haven't decided about the coppering yet. Could buy copper tiles again,or copper sheet and make my own,or just paint it copper I'll have to have a good think about it.Any suggestions/thoughts?
  2. More filling,sanding,primer coat,filling,sanding primer coat,top coat.
  3. Here I go with the first day of filling and sanding.It's coming on well.Hopefully another couple of days should do it.
  4. Hi Nenad, No, the sanding shouldn't be too bad,the planks have gone on really well.
  5. Just one or two small bits of planking to glue in,then the sanding and filling.Then more sanding.... and filling,......and sanding. I've been doing a little bit of sanding as I've been going,so won't be too much to do,I hope!!
  6. Slowly getting there. I'm using 2mm thick planks,which will allow for a good sanding.Hoping to get away with not putting a second layer on,all depends on the finish after it's been sanded and filled,and sanded again.Should be okay seeing as half of it will be coppered and the rest painted.
  7. I do like planking.In fact,I must be pretty good at it,as someone called me a great planker the other day.At least that's what I think he said.
  8. Well,here we go with the first strips of planking. By the way,total cost so far is £12 for the sheet of plywood.Everything else has so far been used up from bits I had left over from previous projects,but I daresay the cost will be going up soon,as I run out of stuff!!
  9. Thought I'd get on with a bit more work on the rails today.
  10. Thanks Omega. I might have a change in the next day or two and start planking the hull. These small bits and pieces are very fiddly!!!
  11. Thanks Nenad,but don't forget,I'm retired now,so have a lot more free time!!
  12. Not much to show for today's work! Started on the second hatch and toilets.
  13. A bit more progress on various pieces today.
  14. Thanks Bob,they're actually some small portholes I had left over from another build.
  15. More work on captain's cabin and skylight. Door handles are the heads off brass tacks.
  16. A bit more work to the stanchions,and getting the rail into position.Tops of stanchions will be ground down flush.
  17. Starting on the skylight for the captain's cabin. Note the piece of polythene to stop the glue sticking where I don't want it to!
  18. A bit more work on the Captain's cabin.
  19. Just a bit more progress today,been taking it easy watching the F1.
