Marinus
Everything posted by Marinus
  1. The planking of the Quarterdeck is done. Next job is the sanding and putting on the varnish. After that I will do the lining of the gunports.
  2. Fitted the gunport strips 276 in place. Only glued the strips onto top gun port pattern 270. This way it is easier to remove the uprights 1 to 5 on from the bulkheads. Removed the uprights on bulkheads 1 to 5 and 10 to 13. I used a Dremel grinder to remove the uprights. Fitted the quarterdeck screen assembly and removed upright 14. Next will be the quarterdeck planking.
  3. Got the Upper Gun Deck finished and glued the back end of Quarterdeck in position. It will cover a lot of work done, but I think they call that progress. Luckily I am a reader, but I never thought I would use the books for this.
  4. Thank you all for the thumbs up. I also like to thank Charter33 for his great building log, I use it a lot and get some great help from it. I also use Robert29's building log. Thank you both.
  5. I got one side of the cannons rigged. I only fully rigged 7 cannons, the other cannons I only did the breaching ropes. You don't see them later anymore.
  6. First cannon rigging done. It is a lot of work but I am happy with the result. I changed the hook up on the deck. The hooks provided with the kit are to long.
  7. It is almost a year ago that I worked on the Victory. My wife got very sick and needed me to help her, she is doing way better now. I finished the copper plating and starting now with the rigging of the cannons. I just add pictures of my progress to my site. There is already a lot of great advice and helpful hints on the website. Thanks to all of you, it helps me a lot.
  8. The Port side is sofar done. I will buy a paper cutter to cut the rest of the missing plates. I will start next with the Starboard side. It's not perfect, but I am happy the way it turned out. First time I did the copper plating. Any suggestions are welcome.
  9. It's been a little while that I worked on the Victory. We moved to a new house and it took some time to set everything up again. I am working on the cannons and the copper plating of the hull.
  10. Happy New Year to you all. Back working on the Victory. Painted the hull and Cannon carriages and started the copper plating. Have to touch up some spots on the hull and paint the gunports. The instruction says that the outside edges should be yellow, but the real Victory has everything painted red. Didn't make a decision yet what to do. The cannons take a lot of time, same as the copper plating. I will find some other things to do on the Victory in between so I will have a break from it.
  11. Gunports lined and painted. Painting the inside bulwarks, it takes a lot of coats to cover nicely. In the meantime in between the painting I started the Cannon carriage assemblies.
  12. Lower gunports lined on the starboard side. Not as difficult as I thought but still a very challenging job, patience helps a lot.
  13. Got one gunport lining done, many more to go. I like to thank all Victory builders who posted a lot of great information to make it easier for new builders. 👍
  14. Hello, the golf season is ending and I am going to spend more time at building the Victory. My next task is lining the gun ports. I looked at other builds and got a lot of good information how to do this. If somebody has some advice how to do this I am happy to hear from you. Regards, Marinus.
  15. The wales are done. Next I am planning to do the rest of the gunport linings.
  16. Lined the gunports with no lids and planked the inner bulwarks. I will paint the bulwarks after I lined all the gunports and installed the beam shelves, stringers and waterways. It was a time consuming job but I am happy with the result. Now back to planking the outer hull.
  17. Upper Gun Deck planking done. Now sanding and applying several coats of matt polyurethane varnish.
  18. The holidays are over, so back to work. Lined up and installed inner bulwark patterns 275. Started the Upper Gun Deck planking and after that I will line the gunports 3 till 10.
  19. First stage done of the second planking. The planking didn't go exactly as I had planned but it looks ok and I made it very smooth with a lot of sanding. I will get some primer and spray that on to y the waterline so I can see if I have some more sanding to do. I will continue planking upwards to just below the upper deck gunports and will then install the upper gun deck and do the upper gun deck planking.
  20. The second planking is not going exactly the way the schip was build in real live but it is looking okay and most of it will be covered with the copper plates. Forgot to taper the planks when I used Chuck Passaro's bending technic.
  21. At first I had no idea what you mend with the garboard strake. So I downloaded the"planking project beginners pdf" and now I understand what you tried to tell me. Thanks, Marinus I signed up. Also I watched Chuck Passaro's videos and use that technic now. Thanks again for your help.
  22. Hi Allan, thanks for your response. I indeed looked at articles about planking and I agree with you for not using the treenails. I find it doesn't look good because on most of the samples I saw the treenails are to big and makes the deck to busy. I will try on the upper gun deck to use thread to simulate the space between the planks. Marinus
  23. Two of my previous builds. Smit Rotterdam and Zwarte Zee.
