Alva004
Everything posted by Alva004
  1. Mark...I laugh so as not to cry, now I have managed to get the longest one and two or three others to come out in English...and the ones that used to come out in English are now in Spanish. Wait, I'll try at some point, try again, to see if I'm lucky because today I'm exhausted with attempts. Greetings.
  2. A fantastic job, I will be attentive to its completion. Greetings.
  3. Good morning everyone. Last night I tried, for three times, to do the subject again and indeed Mark, there comes a time when I don't know how or why, despite having written in English, the Spanish is converted, even some paragraph comes out in both languages mixed. This afternoon I try an idea I've had to see if it works. But the problem is the size of the theme. Thanks.
  4. Dave: Forgive me for abusing your help, can you check if the beginning is now in English? Thank you.
  5. Dave:
    Thank you.
  6. Good again, explain to me what happens, I use the google translate Spanish to English, I copy and paste the text in English... I put a lot of effort into it because I'm not used to it, I know it's a forum in English and I've read the rules. I need to know if something is happening, because making an effort that doesn't work out doesn't make sense. Does it appear in English or Spanish? Thanks.
  7. Thanks Glen...yours junks are really beautiful. Regards.
  8. Good night Mark. I am using Google translate in all my interventions... What has been the problem? What happened? Someone problem? I don,t understand your message. Greetings.
  9. Good afternoon: The first thing would be to apologize for having written in Spanish... but that would be a lie. I write in Spanish in Google translate, I copy the English translation and I always have it. Let's see if this tenth attempt goes well and if not don't blame me and see if someone with more knowledge in this tells me what can happen and how to solve it, thanks. I have already identified the problem every time I edit two or three paragraphs, I have to go image by image and click to edit, all of the above is passed from English to Spanish. I'm going to see if I can do it in one fell swoop, and if it doesn't work, I give up. Let's do it on an eleventh try. The junk is possibly one of the oldest known sailing ships, having been documented to appear in 600 BC and is still in use in many parts of Southeast Asia. The technique of manufacturing watertight compartments from Chinese junks. The hull has a short stern and no keel. They were the signature ships of the China Sea and were used by both Genghis Khan and Kublai Khan in their attempts to conquer Japan. It was produced both for war and for trade. In the 9th century AD. C., Chinese junks transported goods to Indonesia and India. Its sails are made of thick fabric joined with reeds, which gave it great stability and great thrust. The rudder was removable and higher than in common ships, which allowed it to navigate in shallow water. It was one of the favorite ships for piracy on those shores. They were typical throughout the Asian area, with subtle morphological differences between them, but the essence is the same in all of them. I was able to make this boat from plans, which was a real relief for me, because of the ease of having all the measurements, mast angles, deck accessories, etc. once its size has been adjusted to the bottle. It was my fourth boat and I hadn't officially finished it yet, so I hope to do it here. He met problems and challenges as they arose and relied on imagination and invention to get him through. They are missing because some images have been lost but I think the most important thing is. I'll try to explain the process as best I can, but don't forget to use Google translate. Thais is the plan I usted. The technique regarding the hull is the hull divided into two to be able to access the inside of the bottle. Solid hull, we cut the main shape with a fret saw, which we carve with knives, files and fine-tune with sandpaper. Scroll saw and try to get as close as possible to the shape and curves of the ship. There's a lot of work left on that hull, and pictures are missing but it's all razor and sandpaper work. The different forecastles and sterncastles are also well prepared following the plan. With some tinted and adjusted polo sticks we will make the tops and simulate the planking scratching the stick with a pointed tool, not sharp, I used a fine nail to improve the point. We have advanced in the hull, the decks and the masts, all following the dimensions of the plan, we have painted the hull inspired by a photo on the internet in which one appears with red sails. We also have the keel made The masts have pins at their base that penetrate their respective holes in the deck. It facilitates the work and at the time of assembly the ventral part will only be cut one or two millimeters so that it does not collide with the glass roof of the bottle and to be able to assemble them. Prepare a mold to give the sails a little curvature to simulate the effect of the wind, there are those who maintain that the sails of a junk or sampan do not bend due to the effect of the wind, If they are made of interlaced bamboo, you will not see the bulging effect of the air, if they are fabric, don't hesitate, they will bulge. Well, the mold is made from Chinese skewer tips and, for the most part, ear swabs. The fabric is adjusted, taking care to insert kitchen paper between the mold and the fabric. The fabric is soaked with water and pva in equal parts and adjusted to the mold, we will always cut more fabric than necessary after adjusting the cut. Once dry, the crossbars are made by sharpening toothpicks with sandpaper to sharpen them. The Sails are already configured to suit you, exactly the same as the plan, they are sewn to the mast, thread and needle and we reserve them for when they have to be finished. Cheers
  10. Welcome Rich. My english is very bad, but figth for It. Try not work ever with Google translate. In this time write with my poor head. Greatings.
  11. Good night: Thanks for your interest, I have already published two, they are where they have indicated. In the Gallery of finished boats from scratch. If I can or know how to do it, I'll put the link to the first one and they're both. Tonight or tomorrow I will put the third. I want to put up to the seventh bottling, I'm working on the eighth. And if there is interest in making compilations and also step by step of how I did two of them, I don't have images of all of them. All the best. https://modelshipworld.com/gallery/album/2581-my-first-ship-into-a-bottle/ https://modelshipworld.com/gallery/album/2582-my-second-bottle-boat/
  12. My first ship is already published in Galery. It's the second simplest, and my first bottled boat... I'm going for the eighth I think my learning curve is not bad, they'll tell me if they like it and follow the next publications. Keep in mind that I am self-taught and have only been three years. That you like wish.
  13. Thanks everybody. I'm going to try to post my first boat right now...let's see if I can. I'll do it in Gallery thanks for the advice. You are all very kind. Greatings.
  14. Greetings to all: My name is Alvaro, three years ago I started with naval modeling, my specialty in fact I do not do anything else, they are ships in bottles. I will be showing my works in chronological order waiting for kind criticism, suggestions, questions, anything you want, it will be welcome. If you feel something strange in my language, it is because I use the Google translator. I am from Spain and unfortunately I do not speak English, I hope this is not an impediment to understanding the message and participation in the forum Good day.
