EDD W
  1. Get a sheet or block of foam/stiff sponge/polystyrene, cut of the tip of a cocktail stick and put a small ball of Gorilla Tack on the end. pick up the item to be painted with the gorilla Tack and place it upright into the foam/styrene base. Now you can paint the part by hand or spray. When dry remove part and turn over (the gorilla tack will not leave a mark), then paint second side. the cocktail sticks and balls of tack can be used again and again.
