Beginner
Everything posted by Beginner
  1. Hi, building my first wooden model and having enormous difficulty with the nail/pin pusher. 90% of the nails bend before they are fully through, occasionally the wood splits,not sure if I’m supposed to use the pusher just to get it started and then swap to a small hammer. I’m using the Artesania tool. Any suggestions would be appreciated.
  2. Hi,
    Initial progress on the Artesania Marina 11, up to attaching deck to frames and at this point questioning how to ensure deck / glue / frames all make contact long enough for glue to take strength.  As you may recall the tops of the frames where they will/should make contact with the deck are curved initially up from the false keel and the downwards to the edges of the frames, also curving down from bow to stern. Using either contact or white glue I am assuming the need to clamp numerous points of contact but due to curves of the frames have yet to find a successful manner in which to secure all points of intended contact.
    I  would be most appreciative if you can recall how you assured contact at all points was achieved while the glue set.
    Thanks and regards Beginner (Colin)
  3. Hi, just starting Marina 2 and believe your post is going to be really helpful - thanks for taking the time to share. Like the stand you built, do you happening recall where you found the plans or did you create your own. Regards Colin
