Dave Wood
Members-
Everything posted by Dave Wood
Various tweaks made to design to make it closer to the real ship Most complex was funnel shape. New design at top, real ship middle, previous design below
- 19 replies
- Queen Mary 2
- 3d printed
- 19 replies
- Queen Mary 2
- 3d printed
First full multi colour print ultimately failed due to incorrect gaps between the spars and the supports - that I think were introduced when I sliced off the sails for printing separately. Errors corrected, plus a few more stabilisers added. Short Timelapse showing the failed print attached in case it is of interest. https://youtube.com/shorts/-zQjY5tjEkU?si=aOISvMHEPT9lEw5r
Had a few problems about 65% in with the supports for the front and middle sails failing. Managed to recover with some white Blutac - and print now up beyond brown spars for both problem sails. Might be due to the 5% size reduction or a general weakness in that part of the design - will beef up the supports before next print.
Reprinting Sea Cloud on a BambuLab H2D as a single multi coloured print. Had to reduce the scale down to 95% to make it fit on the centre section of the build plate - which greatly saves on print time. About 22hrs projected - with H2D doing about 950 of the 1200 changes via nozzle swaps - between brown and white - so no purging required. Print about 30% complete with no issues so far.
Deck13 reprinted - this time with the correct balcony height, retractable roof tiles showing and domes now printing well. Will probably leave the rest of the decks for now as most of the faults are invisible to my naked eye - and only really show up on close ups.
- 19 replies
- Queen Mary 2
- 3d printed
Pretty much every part needed tweaking to overcome minor issues - so complete reprint will be required. Am going on the real ship in a few weeks - so might wait until after the trip before doing the reprint - in case any further corrections identified. Most significant correction is deck13 balconies - which didn't have enough height in the first print - so will reprint deck 13 at lease now. Also created a transport / magnetic display adaptor for QM2 to make it easier to take onto real ship.
- 19 replies
- Queen Mary 2
- 3d printed
First test print complete - the first time I think I have ever used full colour for the first test print - deck 13 came out pretty well - just two of the radar balls didn't quite work. A fair number of updates required - but overall quite happy with the ship so far.
- 19 replies
- Queen Mary 2
- 3d printed
Almost complete - just deck 13 to go. Hull + Deck6 Deck7 Deck8 Deck9 Forgot life boats part of Deck7 - so had to take it apart again to add them + Deck10 Deck11 Deck12 With part printed Deck13 - which I had to cancel due to misalignment of black Close up of back - a bit mess - so some beefing up of railings needed. Middle - some balcony glass issuesFront - problem with Cunard text and a few balcony glass issues. More work required - but fairly pleased so far. Just need deck 13 print to complete - which is about 3hrs in total.
- 19 replies
- Queen Mary 2
- 3d printed
1:1000 version of Model now fully sliced. - 11 colours in total. 0.2mm sections - total projected print time 16h4m. - plates 5,6,7 to go - so about 11h more printing to go. 0.4mm sections - 9h24m - plates 2 & 3 to go - about 6.5hrs more printing to do.
- 19 replies
- Queen Mary 2
- 3d printed
Multi Colour mostly 0.2mm Nozzle looking quite good. Deck6,8 & 9 aft shown - Deck7 all at 0.2mm still to be printed (will make about 5hrs) Life boats and centre sections and main part of Hull printed 0.4mm
- 19 replies
- Queen Mary 2
- 3d printed
Started 1:1000 print. I am print some parts - with small details like railing and text on a BambuLab H2D with 0.2mm nozzles. With the less detailed parts on a BambuLab X1C. Tiny text Tiny detail - in initial 2 colour test print of deck6 Aft Whole ship so far. Using this approach for the 1:1000 model will hopefully mean I can in the first instance simply print the exact same model at 1:500 scale but all on 0.4mm nozzles, split down into smaller parts when print size does not allow it to fit.
- 19 replies
- Queen Mary 2
- 3d printed
More details added - plus short video showing how the decks appear in Fusion 360.
- 19 replies
- Queen Mary 2
- 3d printed
Further refinements made - see here for 360 degree render.
- 19 replies
- Queen Mary 2
- 3d printed
- 19 replies
- Queen Mary 2
- 3d printed
- 19 replies
- Queen Mary 2
- 3d printed
Found I had got the decks confused at the front - had put the observation deck in one too low - so windows were all wrong too. Now corrected.
- 19 replies
- Queen Mary 2
- 3d printed
- 19 replies
- Queen Mary 2
- 3d printed
- 19 replies
- Queen Mary 2
- 3d printed
- 19 replies
- Queen Mary 2
- 3d printed
- 19 replies
- Queen Mary 2
- 3d printed
Made a start yesterday on QM2 Multi Colour 3d printed model - will design it for 1:500 initially, then scale down to 1:1000 Modelling from deck plans from Cunard site and various photos, using Fusion 360. Will then Muti colour 3d print on a BambuLab X1C or H2D. Hull shape needs a bit of work. Will mirror it once a few more decks are done.
- 19 replies
- Queen Mary 2
- 3d printed
