Pitts2112
Everything posted by Pitts2112
  1. I've read every paper and watched every video I can find but haven't been able to get the hang of reliably shaping planks so they not only butt against the preceding one but also lie flat on the ribs. The twist is the part I'm having a problem with. I've tried boiling water, Chuck's drying ironing method, combination of both, all without much luck. Can someone please explain or send me a link to a source that explains/demonstrates it very clearly? Here's an example of what I'm talking about. I've sanded the edges smooth but you can see how the planks were standing off from the robs on the bottom edges resulting in the this profile after sanding.
  2. Funny you should mention that! I just picked up one of their mini planes and some chisels in the lee Valley seconds sale, delivered day before yesterday. I wish their online catalog gave a better sense of scale (it was hard to see how big/small they actually are) but I'm happy with them so far. They're the real deal - work like proper tools and everything! Pencil and scale for...scale (sorry, I didn't have a banana handy)
  3. Does anyone here know if one can buy a set of sails for the Amati Lady Nelson or if there are patterns to be had to make them myself? Alternatively, is there a reason few, if any, modelers seem to put sails on this particular model? This is my first build so I'm not familiar with any issues that might be involved. Thanks very much!
  4. Wow! So many good answers! it had never occurred to me to fix the plane and move the wood but it's obvious now that I've heard of it. I've got several ideas to try out now. Thanks everyone for the help!
  5. What are people using out there as a jig to hold planks for edge planing tapers? I've been using a straight edge and Exacto knife flat on my workbench but I find the wood moves during the slice and I haven't figured out a good way to hold plank and straight edge in place. Photos below show my tapering tools. I use the glued-together-planks as a base to keep the straight edge at the same height as the plank surface which helps. So, I'd like to try planing instead because I think I can get more accurate and consistent tapers. But the only vice I have is a heavy bench vice and I'm using two blocks of oak as the clamping surfaces. It works but it's a bugger to line everything up since I haven't figured out how to secure any one component to another and moving the vice jaws is very cumbersome.
  6. It's July 2025 and I've been working on (and off; mostly off) Amati's Lady Nelson since last Christmas. First thing I want to say is a huge thank you to this community for your very generous sharing of a wealth of information on the craft. I've spent much more time reading posts here than I have actually building the model and all of it has been a delight. I just finished the first planking, which went better than expected but I ran into a situation where I needed far more stealers on the lower hull than I expected. I suspect I didn't properly measure the length of the ribs and stern post which led to tapering too narrowly at both ends. I suspect I only measured the 10th rib and not the stern post since that's where my coverage finished when I had nearly all the planks on. I also know I didn't cut the tapers very accurately, so their actual measurements are kind of all over the shop. I partly corrected this by laying two untapered planks at the keel (garboard and next one above), then doing a very customized gap filler plank to finish the main hull. Covering the stern post required 3 very short, very pointy stealers to make up the difference. I'm pretty sure those should have been longer and more strategically placed but I didn't know I was going to need them until it was too late to plan ahead. It seems to have done the job overall just not according to standard procedure, I think. (see pictures below). Question for the group - is my assessment above correct or is this the result of some other mistake I made (or combination of mistakes)? Pics: First planking, showing wide variation in coverage toward the last couple of planks. I think I tapered too much on both ends which led to them not coming far enough down the bow and stern post and being too wavy overall. Also I think I only measured the last rib instead of the sternpost so only tapered to the end of the rib: Measured gaps between planks and keel when I only had a c9uple more planks to lay. Finished first planking with stealers laid. After sanding it came out alright, I think. Will this be good enough as a base for the second planking or do I need to do something else to it before starting?
  7. First time modeler trying to use Chuck's plank bending method on the Lady Nelson. My question is what's the technique for getting the sharp bend required on the last couple of inches of the plank to get around the first rib and into the bow? I'm getting the bend on the rest of the plank OK, but I've broken 3 of them trying to get that last bit in. I think that if I don't get the bend sharp enough then CA glue isn't going to be strong enough to hold the end of the plank in place. Any tips will be greatly appreciated!
  8. Based on everyone's advice, I think I'll stick with the razor knife and sanding block for now. This will be my first model, after all, and if I think I'm going to notice the difference in results between the methods, I'm probably fooling myself. Thanks everyone for the kind advice!
  9. I'm a firm believer in this tool rule. Until I end up in a tool shop, that is. Good advice on all your points. Thanks very much!
  10. This is the kind of rig I was thinking of, or maybe even a shooting board type of thing since I'm also a little worried about keeping 90 degree angles.
  11. So maybe worth getting an inexpensive plane and trying it out? Sounds good. Thanks!
  12. Hello, all, I'm getting ready to start my first kit, the Amanti Lady Nelson. I've been absorbing the website here which is an amazing resource. I have one question about tools for tapering hull planks. My only experience with wooden models is from a couple of balsa wood aircraft when I was a kid and I remember having a really hard time getting quality results with X-Acto blades on that wood, particularly trying to make long taper cuts on thin strips. Are the planking woods in ship kits easier to work with? Would a modeler's plane give better results than a razor knife? Thanks for any tips!
