wlell
Posts posted by wlell
Jotika Victory Mast Question
On plan sheet 6, topgallant mast, front elevation, there appear to be 2 holes drilled through the mast: one immediately above the 4 mm square section and one below the upper, tapered octagon. Are through holes also required on the fore and mizzen topgallants, or, for that matter, any other
mast section? Since I am constructing the masts from square stock, it would be eas1er to drill anyrequired through holes on a flat surface prior to shaping.
Some more detail on the sheave assembly construction would also be appreciated.
Thank you for your help.
Bill Lell
Birmingham, Alabama
Excellent work Jason. Great detail work.
I suggest you GOOGLE "Instrument Ties" There are a number of video hits showing how to tie knots in tight places using surgical instruments and a small amount of thread. Really all you need is a couple of readily available hemostats. A little practice and you will tie knots like a surgeon.
Good luck
Bill Lell
Birmingham, Alabama
Beautiful work! Before you rig, do not forget to rotate that right deadeye (seen in the deadeye close-up) so the triangle points down. Really instructive build with great photos.
Bill Lell
Thank you Mike. I will use those dimensions for my case as well. Your FLY looks awesome!
Bill Lell
Strong work Mike!! I am near completion of this model and would like to know the dimensions of your plastic case.
Thank you,
Bill Lell
Vestavia Hills, Alabama
Dennis
You are creating another masterpiece every bit as nice as your outstanding HMS Victory. Remind me where you got your blocks.
All the best,
Bill Lell
Strong work!!! Really like your driftwood display. Great idea.
Bill Lell
Vestavia Hills, AL
in Wood ship model kits
Thank you David. I appreciate your help and advice. I follow your Victory build log and admire your work.
Bill Lell
