jwhineryjr
Members-
Everything posted by jwhineryjr
After some encouragement from others on the forum I decided to not be so overly critical with the appearance of something midway through the steps because my work doesn’t look like the pictures of what it should be after the steps are done. So some more pictures of my progress with the gun and sweep ports.
Sanded the filler blocks some more to knock down the sharp bend from the bulkhead to the transom. Still needs a little more but I think I'll wait until I start planking the transom to get a better feel for how much more sanding is needed. I got the timberheads and knightheads along with the top stiffener in place. Going to finish fairing the hull and work on the waterway and planksheer on both sides.
Well, I've reworked the transom and it appears to be much closer to the way it should be. I finally received the replacements parts from ME but I think I'll hold off on redoing the transom from the beginning for the moment. Maybe work on faring the hull a bit and see how it looks. Any and all feedback would be greatly appreciated..
SgtSki in MI, I bought mine about 8 years ago. and really didn't find it to be as reliable as proclaimed. I use the base to hold the center keel in place and usually one of the end frames to square it up. When installing the bulkheads I use blocks to square them with the center keel while I tack them in place with glue. Hope that helps. John
Okay, I think I’ve hit a bit of a road block with the shaping of the stern. Adding the Quarter timbers and shaping the corners is also giving me issues with respects to installing the waterway. It doesn’t sit flush, Now I could gouge out a pathway so that it sits flush on the bulkhead or I could bend it slightly to follow the lines of the corner filler block. Of course as many before I have broken and glued all these pieces more times than I can count and finally contacted Model Expo for replacement Stern Timbers, filler blocks and Bulkhead Q. In the meantime I am reworking that bulkhead to see if I can get it closer to what it’s actually supposed to look like.
GuntherMT, if you read Page 10-11 of the instructions (figure 1-1 & 1-5) and on sheet 1 of the plans it explains and shows where to draw the reference line on the center keel and each bulkhead. Both the top of the bulkhead and the bottom must be aligned between the reference line and bearding line. Now I don't profess to be an expert but in the few models I've done it's always been that way. If others that have this model have done it differently then I certainly would like input before going any further which is why I joined the forum as I want this larger model to look proper. All of the pieces are just tacked together until I'm comfortable with alignment then I do the final gluing so that everything stays put for sanding. I am reading through other logs for the Niagara here and a couple of other forums trying to glean as much info as possible. John p.s. The instruction book even has a disclaimer that there may be error in size of the bulkheads due to manufacturing glitches (it says all laser cut parts).
The bulkheads have been glued in place making sure each bulkhead’s reference line matches the one on the center keel. Once the bulkheads were installed, I tacked a temporary batten to each side of the hull just below the deck then measured the spacing between each port and starboard bulkhead until the hull was aligned. Then I cut permanent struts from 3/16 x 3/16 stock and placed them between each bulkhead close to the exterior. I measured to be sure the hull was squared and then glued the struts in place and removed the battens. Next, I will sand the bevels in each bulkhead.
Hi RevKB, I know what you mean about trying to buy this kit. I got mine directly from Model Expo when it was on sale for $149. Plus I had a discount code and a credit from a previous build for free kit (Sultana) so I was able to get it for almost nothing. If it hadn't been for all those circumstances happening at the same time I too would be still waiting to purchase this kit.
Here we go. The center keel along with the stem, keel and sternpost assembled. I’ve drawn all the reference lines on the center keel and bulkheads including the bearding line. I cut the rabbit into the center keel using 60 grit sandpaper glued to a small piece of wood (3/8 x 3/8 x 2 inches). Now it’s time to prepare the bulkheads and square them up to be glued. I will be using Model Shipway’s Fair-a-Frame to help with this.
Hello to all. I am a long time reader but first time posting a build log. My first wooden ship model was from Scientific America and was built back in 1978 for my father in-laws new office. Since that time I continued building ships every couple of years until the hobby shop I used closed its doors. In 2002 I found Model-Expo and started building again. Like most builders I started with solid hulls then progressed to POF and POB models. Then I started doing kit bashing and small from scratch models. Until the Niagara I had never built a ship with a hull bigger than 16”. Anyway I hope I can do justice to this forum and build.
