Ahoy Mates
Have you used this product for filler-Elmers Carpenters Wood Filler on a wood hull and then planked over it using Titebond to glue the planks over it? Or used another type of glue?
Has it worked out  for you? or did you have problems?
I will be planking with boxwood and swiss pear over the hull and some areas  that will be covered have this filler.
Thanks
Keith
Thanks for the good news Brian. I also drilled some .020 dia. holes into the wood thru the filler so that the Titebond will have contact with the first layer of planking under the filler.
Keith
Edited by bear
