HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 64 donations so far out of 49,000 members - C'mon guys!) ×
Before we get to my (first!) build log— WOW, did Summer put a whammy on my building plans!  I created my New Member Introduction and actually started my Dory back in April, hit a technical snag in May, and then all the normal and enjoyable summer activities kept me from putting any serious building in.  Spent lots of time with the kids and grandkids, camping trips, ball games, concerts, cutting the lawn, etc.  My "workshop" (just a small corner of the garage) had to do double-duty for household repairs, projects, and just plain junk collecting.  Got it all cleared off this week, and finally got back at it tonight.  Whoo-Whoo!
I’m glad that I decided to start “small” with Model Shipways Lower Grand Banks Dory.  It’s teaching me a lot—stuff that I knew I didn’t know, and some stuff that I thought I knew already.  Been a great experience so far.
There are a lot of logs already on this kit, and I’ve been reviewing them all(?) for hints and solutions.  I know a lot of newbies like me are using these logs, so I’ll try not to repeat what’s already been presented.  I’m sorry I have a lot of text here to catch up with where my build is;  I hope it is useful for the other beginners..  Here goes.
I assembled the bottom planks and cleats no problem.  I thought of simulating the prototype nails like some builders have done (nice job!) but thought better for me to stick with the stock kit build.
I’m afraid I may not have heeded the instructions closely enough on keeping the stem and stern knee square while removing the char, but I feel that I can make adjustments / repairs if I need later.  (Sorry, I lost my photos of my part.)
Overall, I’m having a time of it removing char from the parts—how much is enough, keeping the part square while I remove it, etc.  I find that my fingers just don’t hold the part firmly enough to keep things from rocking, even while sliding the part along a guide (as shown in the instructions).  I guess this will come with more practice?  I’ve read lots of advice on the forum on this, using certain sandpaper grits, straight razors, x-acto blades (even sandblasting!). A special thank you to Mr. Passaro’s perspective and encouragement on this topic.  I still don’t look forward to this part of the process.
On adding the curve to the bottom—I had to repeat this process several times before I got what seemed to be the proper curve.  It seemed that there wasn’t enough “offset” in the spacers to  counter the natural springiness of the wood.  I had to use thicker spacers, and a lot more water than I thought it would take.  However, when it came time to mate the bottom with the frames, it fit pretty good (except for one thing, below).
Now here’s a small beef, or maybe just a “Huh.” Or maybe just a watch-out.  I was surprised to find that the profile drawing on pgs. 4 & 5 are not to scale, the drawing being about 5% smaller than the parts.
This may not seem like a lot, but it eliminates using the drawing to help with the relative alignment of the left and right frames, and makes unnecessary the direction to “Assemble frames over these patterns.”  For a beginner kit, it would have been more reassuring if the parts and plan matched.  Please correct me if I’m missing something here.  l went ahead using the template parts as the sole basis for my frame assembly, and so far, with out doing the planking yet, so good.  (I noticed that the photo of the ruler/scale on page 7 is right on.). Used lots of my T-pins (I love these) to keep everything in place.
 Setting up the frames on the building board, and gluing the bottom (on “top”) went well enough.  I broke and separated some frames while sanding the char off (grrr), but glued them back together no problem (this is how it goes, eh?).  I didn't need as many rubber bands as I thought I would.
I did have one anomaly in that for some reason 🤔 frame #2 was too short, and didn’t meet the bottom, and didn’t follow a nice curve with it’s adjacent frames.  Not sure if I sanded too much while removing char from the bottom, or mis-aligned the frame halves while gluing, or what.  Solved this by shimming the #4 frame cross-piece up a bit to meet the bottom.  Looking ahead, it seems to me that I’ll have some play in the final “height” of the frame at the gunwale while cutting the frame free from the cross-piece.  Will need to keep an eye on the thwart and riser placement.  We’ll see.
That’s all for now, the frame/bottom glue is drying.
Just for fun: (I almost feel like a real nautical researcher here) I was at the nature center at Crane Creek State Park (on Lake Erie).  There is a nice exhibit on historical waterfowl hunting, and I noticed that their punt boat has a lot of the same construction elements as our Grand Banks Dory.
When I built the dory model, I had trouble getting my frames assembled straight. Maybe because I didn't notice the printed patterns were not quite to scale?
Your post makes me realize that open boat models like this dory are really pretty challenging to get everything lined up just right. I'm building a lobster smack now, which, having a deck, conceals a very solid skeleton inside, to which everything else is attached. That gives the boat a much sturdier shape than having to just attach all the exterior parts to one another.
  • 1 year later...
Well, it’s been just over a year since my last post, but I’m back at it— progress was stopped last winter, and slow through summer, but fall has been much more productive.
I finished the planking, and just popped the hull off the building board today.  I am mildly pleased.  The results of having trouble lining up the strakes with a consistent overlap show up in the bow and stern views.  I botched the alignment on the port second strake but didn’t realize this until after the starboard went on.  I decided to chalk it up to learning, and keep going with what I had.  I’m hoping that I can hide some of the jaggedness in the bow with the false stem, being soaked now.
Learnings, BTW:  I had to soak the wood much more (like 24 hrs) than I thought in order to get a good bend.  I just clamped the soggy strake to the frames, and they held almost a perfect shape when dry.  I used mostly the glue provided in the kit, but found a little dab of CA can work wonders in a pinch.  Isopropyl alcohol works like a champ to unglue big whoopsies.  ("Whoopsie" is not the word I used at the time. 😇).  Best tool, besides a new #11 blade:  my wife’s used nail file emory boards.
IMG_7634.thumb.JPG.0120d894e8f8f029395fa885cb620e2f.JPGIMG_7636.thumb.JPG.5fe734d1d334b668d01d4275df7e5dea.JPGIMG_7635.thumb.JPG.a6ee814e2d51ee091f8c9b9d7929d3b9.JPG
Will my pencil marks show through the paint?  I’m nervous about sanding down to much.
A total upside was shaping the oars—very please with these.  I now know why 5 blanks were provided in the kit!  The “handles” were constructed in two ways:  the ones that didn’t break off were shaved down from the blank, per instructions, and the others are round toothpicks glued into drilled holes in the end of oar.
I’m glad for the portable heater in my garage workshop.
This is looking good.  Yep...learning process continues with every build.  Yep...every kit has some 'anomaly' that doesn't show up until you assemble it.
And you probably will notice the errors more than a lot of other people when the project is complete. We tend to be harder on our own critique of our work.
However, you are doing (IMHO) the correct procedure: Keep Calm and Carry On.
And as a QA manager told me what they did on the factory floor:
File to fit.
Hammer to adjust.
Paint to Hide.
Robert Chenoweth
In the research department:
Nothing at this time.
Thanks for the encouragement.  I’m all in with “File to fit” and “Paint to hide”, but I sure hope I don’t have to resort to “Hammer to adjust” on my little dory.  Actually, while I was taking the photos for my post, I dropped my cell phone right on top of the dory, and other than a mild heart attack, no ill effect.  😅
