Flying Cloud Bowsprit Jibboom Line/s Rigging Help
Go to solution Solved by rwiederrich,
Hi All,
Soldiering on with my Flying Cloud, 1/96 Mamoli.
I am at a stage now placing Blocks/Eyebolts on the Deck and Hull
Unfortunately, supplied plans are not at all clear on where the Eyebolts are located for the Bowsprit/Jibboom lines terminate on the Bow/Hull.
On the plans there are 5 Eyebolts located on the Bow for the various Bowsprit Shrouds/Stays, that's fine, but where exactly are they located on the Hull.
Are they all in a straight line or staggered above or below each other?
How far, what distance are they spaced vertically and horizontally on the Hull?
(At the moment, I am thinking they are located on the Upper Rub Rail just below the Catheads, but again, no real idea.)
The only thing that I am sure about are that there are five Eyebolts per side.
I have looked at the Lankford instructions for the Flying Fish and Scott Bradner's plans but cannot see anything absolutely definitive.
If anyone has some diagrams/approximate positions of these, it would be very much appreciated.
Cheers and Regards,
Harry.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
Sergal/Mantua Cutty Sark
A/L Pen Duick
A/L Fulgaro
Amati/Partworks 1/200 Bismarck
A/L Sanson
Well Harry,
I know what McKay did on his last clipper, Glory of the Seas.  Not shown in this image, is her jibboom stays...which were all(four per side) inserted along the front of the cathead. You can identify the bullheads.
Current build:
Finished build:
Current build(On hold):
19 hours ago, rwiederrich said:
Well Harry,
Hi Chap,
Thanks for that, Great Photo!!
More food for thought....
It's looking like the chain Bowsprit Shrouds are well below the lower Rubbing Strake. (Good to see there are two per side, only one on the Kit, same with the Bobstay/s.
Yup, happy with the Jibboom Stays, they terminate on the Catheads via Whisker Booms on the Bowsprit cap.
Concerned regarding the three (6 total) Foremast Stays, I am wondering if these should pass through holes at Bow Bulwark level and terminate on the Fore Pin rail.
(In your photo, I note the Fore Topmast Stay/s running through the "Bee" but were does it go from there?)
Thoughts?
Cheers and Regards,
Harry.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
This painting of Flying Cloud clearly shows the stay arrangement.
Current build:
Finished build:
  • Solution
In this close-up of Glory of the Seas...you can clearly see the fore topmast stay pass through the Bees....and back toward the root of the bowsprit...where it terminates.
Not sure if McKay used this arrangement on Flying Cloud.  She still sported single topsails.  Near twenty years separates their evolutions.
Current build:
Finished build:
Hi Chap,
Thank you once again.
Another great photo!!
It looks like the Fore Mast Fore Stays all head towards the Fore Pin Rail, or somewhere near there.... Maybe? (It's driving me a bit "Nuts." 🙂)
I need to have a look at Scott Bradner's plans, (Pin map), to ascertain where these Fore Stays terminate.
One other method that came to mind this morning would be for me to "Mock-Up" the Bowsprit/Jibboom in situ using "Art Wire" or similar to enable reasonable placement/termination points of all Bowsprit rigging on the hull.
Anyway, Still thoughts. 🙂
Cheers and Regards,
Harry.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
@rwiederrich
Hi Rob,
I found the following:
Flying_Cloud_Bradner_rigging-side-view.graffle
I think this goes some way to solving my issues.
Onward and upward perhaps.... 🙂
Thank you for your continued assistance and awesome photo references!!
Cheers and Regards,
Harry.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
On 3/21/2025 at 7:31 PM, hof00 said:
@rwiederrich
Hi Rob,
Cheers and Regards,
Harry.
Just remember....there are no photos of Flying cloud....just models and speculation.  Duncan McLean describes her hull and deck furniture the best.....however.  The photos I provided of Glory of the Seas...McKay's last clipper
Must be your best option.  I cannot assume he would have done things differently.  These images are *EVIDENCE*.
Will you be correcting the kits cutwater and stem to replicate as she was originally built.  Utilizing McKay's secret *Naval Hood* design? Contemporary paintings and models clearly get her bow wrong...simply sticking the figurehead on the stem.  This photograph of Glory of the Seas....depicts McKay's famous *Naval Hood*.  Note the location of the figurehead...on the Hood under the bowsprit!
Drawing by Clipperfan.
Rob
Edited by rwiederrich
Current build:
Finished build:
Rob
Hi Rob,
Many thanks for that.
I think that it is already too late to embellish the Stem at this juncture.
I have already attached the Bowsprit/Jibboom and am proceeding with associated Chin Rigging.
I could try and modify thigs but i do not want to risk damage on what I have achieved over the past few days.
I am however ensuring that Bobstays and Shrouds are Doubled up, the Kit only allows for one Bobstay, one shroud per side.
Once again,
Thank you for your assistance, very much appreciated.
Kind Regards,
Harry.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
